ADVERTISE HERE - FREE TRIAL
Cherry bowl w/ bark
Cherry bowl w/ bark
Cherry bowl w/ bark
Bill MacLachlan
>Found this burl under my bench and wasn't sure what to do with it. Decided to turn this thicker sided bowl. Sides are about 0.500" and thought any thinner wouldn't be a good idea.
Finished with DEFT and Beall buffed. Size = 8 x 5.
Comments appreciated.
Re: Cherry bowl w/ bark
Bruce Forrest
>Since you asked for comments, and no-one else has piped up yet, I'll venture a couple. I like the wood and the general shape but as far as thickness is concerned I think you're in a no-man's land between the thick/sturdy/rustic/primitive and the thin/delicate/artsy. I might be tempted to try to turn a bit thinner to get over to the delicate side, but I don't know how fragile this piece is. Maybe with some care, some CA and maybe wrapping the outside with tape?? I'd also like to see the curve tucked under at the bottom. Even as it is,it's a nice piece, but I think it could be made even better. Of course, my opinion is worth what you paid for it.
Jack Savona
>Bill, I generally agree with Bruce's comments.
I do like the piece of wood you chose. However a few things distract me. In addition to its thickness and the abrupt ending of its curved side at the base, I guess I always look at a natural edge bowl to have a constant flow at the rim. If I had that piece I'd probably use a Dremel or some other tool to curve out any flat spots on the rim and burn the cut rim to blend it in.
If you choose, reverse chucking would allow you to reshape the the base curve and allow the rim to develop an outside curve to match the inside one.
You may also decide to do nothing and say, "I like it just the way it is." It's YOUR bowl and you get to decide. That's the beauty of it all. But thanks for posting. It's enjoyable to see who's doing what.
Jack
