Rose Engine Lathe
Rose Engine Lathe
Rose Engine Lathe
Bob Fawcett
>Is anyone building the rose engine lathe from the last AAW mag?
The plans are up on the AAW site.
I am looking at this and wonder if you couldn't make it completely of wood and MDF. Why couldn't the pieces of metal be substituted with hardwoods? With the possible exception of the spindle shaft I think you could. It would be a little less durable, but with the right hardwood selections it should have a decent service life.
What do you think?
Re: Rose Engine Lathe
>Bob I don't see why it won't work. You would develop more slop in the system both initially and in the future but it would probably work as well as the jury rigged router set up I working on now. The biggest problem would be the cutters and that mechanism. Even so you could use a router but it would limit your cuts quite a bit.
Bob Fawcett
>I also thought about a flex shaft tool.
For the rocking mechanism, how about glider chair bearings?
