skew grinding
skew grinding
skew grinding
peter kolb
>I'm having problems sharpening a skew. I profile the 30 degree slope using a belt sander. OK so far. Using the Wolverine skew sharpening jig, I lose the 30 degree slope at the cutting edge. However, the slope appears at the base of the bevel. Do I need to grind more? Thanks for your help Peter in south central nj
Re: skew grinding
Re: skew grinding
eliot d
>It's a bit difficult to follow just what problem you're having. But sharpening a skew is one of the easier sharpening tasks to master. My suggestion is to get the DVD on the skew chisel by Alan Lacer. It's packed with information, and he spends a fair amount of time on sharpening. He doesn't use any jigs; he does it "by hand". It's really not that hard, once you see how.
Re: skew grinding
Re: skew grinding
Barry Turner
>I have the Wolverine skew sharpening jig. It works well for me only if the skew already has the correct angle and bevel. For me, it's easier to just use the adjustable tool rest that comes with the Wolverine sharpening system. Lay the skew flat on the toolrest. Adjust the angle so that the bevel is flat on the grinding wheel. Then sharpen the skew with the cutting edge parallel to the grinding face of the wheel. Grind with the same number of passes on each side. Make adjustments in technique as necessary. I think this is a more straight forward method than using the skew-sharpening jig. Try it and see what you think.
Re: skew grinding
Re: skew grinding
Jorge Castaneda
>Peter,
I think 20 degrees is the standard and then the bevel is twice the thickness of the iron, with 30 degrees you are making it too extreme.Sribe the 20 degrees and with the belt sander get tha shape right, now scribe the bevel, you can get it started on the belt sander and then if you have a jig use it the complete the job, I can free hand it and think it is the easiest way of doing it.
I dont stop thete, once I have the shape right, I go the the oil stones, medium india and then Hard arkansaw until it is a mirror finish. From then on, it never goes back to the grinder, unless something mayorly wrong happens, like dropping it in concrete, or running it against the chuck. The oilstones takes only a few sweeps, if you do it frequently.
Alan Lacer has a saying: If you can see the edge, you have no edge"
Keep trying and good luck
Jorge
ps If you have a "scary shar" set up, you can use that too.
Re: skew grinding
makes no difference how
Jimmy Edwards
>anyone sharpens a skew because I am absolutely scared to death to use a skew. I have literally screwed up six lidded boxes. I will not use it again until I get the videos and set aside a weekend to practice on scrap. I am a totally frustrated defeated beginner skew user. But i HAVECOJONES AND WILL MASTER AND LEARN IT. bummer
Re: skew grinding
Re: makes no difference how
Jim Shewan
>I too had some problems learning to use a skew but I found its easier to learn with a very large skew as there is more usable edge and the point is well clear.
Quite suddenly you'll GET it and find that useing a skew is one of the most satisfying tools to use.
Re: skew grinding
jared
>Hello: I had an order to make 160 bottle stoppers before christmas. I decided that I would use that job to learn how to use a skew well. I have Alan Lacers narrower skew and it didnt take me long to get the real hang of it and by the time I was done with all 160 stoppers I believe I have a firm grasp of how to run one with no catches. Its all repetition, just keep doing it over and over. I also have both of Lacers videos and they were a great help in learning to run one of those tools that a lot of people seem to hate. Jared
Re: skew grinding
>Jimmy Boxes probably aren't the best thing to learn on. Actually no real project is a good thing to learn on. Put a scrap piece of wood between centers and just turn shapes. Don't worry about what they look like or if you screw thead a bead, just turn and try to get the feel for rubbing the bevel. When your done playing toss it.
If you'll spend just 15 minutes a night you'll get comfortable with it in no time. I also recommend Alan Lacer's video's. The instructions are spot on but you still have to practice.
I'm going through the same thing now learning to hand cut dovetails. I did some years ago but want to get good at it. I go in the shop each night that I can and cut 2 dovetails with the saws only. I'm just trying to learn to use the saw as accurately as possible and to get the feel for laying out and fitting. Once I have that down I'll design a couple of projects that don't matter how they look. I need some simple boxes around the shop. I figure once I get a couple of those under my belt I'll feel good enough to start a real project.
Re: skew grinding
Re: skew grinding
>I'm with Barry. I don't use the skew grinding jig. I either hand grind or use a gadget I built for the flat wolverine tool rest. It has a lip so it rides on the flat jig and can slide back and forth. Then I mounted 2 small strips at angles on the top to give me the correct angle for the skew. I just put the skew in this and move it back and forth to grind one side. Then flip the skew and put it on the other side and grind that side. thenI go to the diamond hones.
You can still screw up. If you put too much pressure on one side or stay in one spot too long while your grinding you'll throw it off. It's just like any jig, not perfect but a big help.
Re: skew grinding
Re: skew grinding
Russ Fairfield
>The skew is a tool where the sharper it is the better it cuts. It seems to me that ALL tools are this way, but that is another story. Anyway, the skew should be the sharpest tool you own, and hair cutting razor sharp is a worthy goal. It should be given all of the same sharpening care as we would give to a wood chisel, the iron in a hand plane, a carving tool, or a fine pocket knife. Remember that all of these tools cut the same, and the only difference with the skew chisel is that the wood is spinning.
The problem with a grinding wheel is that it grinds the tool, and doesn't sharpen it. Grinding is a good place to start, but it has to be followed with a minimum of honing with a flat hand held slip-stone; or better yet, a bench-stone, fine sanding medium on a flat surface, or a hard felt buffing wheel with jewers rouge or finer polishing compounds. For a final step,stropping the edge on a piece of hard leather will get that final degree of "sharp".
Re: skew grinding
Russ Fairfield
>I submit that the biggest problem with learning to use a skew chisel is that it isn't sharp. The sharper the tool, the easier it cuts, and the less are the forces that are trying to make it go in opposite directions from what you intend. Work on honing the cutting edge to a smoother keener edge, and see if it isn't easier to use.
I always pose the question - If you wouldn't be satisfied with a carving chisel or a hunting knife that was sharpened with an 80-grit wheel, why are you trying to use a skew chisel that was sharpened that way. Both edges are doing the same thing. The only difference is that the wood is spinning when you are using the skew.
A lot of people have watched Alan Lasers video or demonstrations and still have problems because they missed the most important part - honing the cutting edge with a slip-stone.
Re: skew grinding
Re: skew grinding
peter kolb
>As per your suggestions I used the Wolverine flat tool rest and the results were perfect. Thanks all Peter in south central NJ
