Small cherry bowl with pyrography
Dominic Greco in Richboro PA
>Hello Everyone,
Here is a small cherry bowl I turned last month. To be honest, I'm not all that thrilled about the profile. I was going for a bowl with little or no foot. But I hollowed a little too deep and ended up using part of my tenon for the foot! I am pretty happy with the bead around the top, and the thickness of the walls. I hardly turn anything this thin (1/8" thick) anymore.
Anyway, I wanted to try out some simple pyrography and this bowl was the perfect subject. Before I go any further, I'd like to thank Molly Winton and Jennifer Shirley for all their advice on pens and such. You both were a great help!
I burned the 2 lines with a guitar string while it was on the lathe. After that I made a cardboard template and drew the curves in between the lines with a sharp pencil. The template was made with some registration marks so that as I moved it, I was able to index it just the right amount. After I drew the lines, I burned them in using my Burnmaster Hawk.
Dimensions:
  • Height:3.5"
  • Width:5.5" dia
  • Opening:4" dia
  • Foot:2" dia
  • Wall Thk:1/8"
Finish: Watco's Danish Oil, followed by Beall Buffing, and Renaissance Wax
A couple things I learned about burning and wood burning pens.
Number 1: If you're using a Standard Detail Master pen, it will get HOT when in use. Wrap it with neoprene tubing (thanks to Andi Wolfe for that suggestion)
Number 2: Like all woodworking tasks, use the right tool for the right job. I used the writing tip to burn all these lines and had a devil of a time keeping them straight! I should have used something like a small or medium skew pen (ex: #11 from Optima). Since it's shaped somewhat like a knife, it won't follow the grain as a rounded tip would.
After that experience, I ended up ordering several pens from PJL Enterprises. I really like the design of these pens. And after talking to Pat (the owner), I was sold.
A short word on Optima pens. Rather than being made from aluminum (which conducts and radiates heat really really well!), Optima pens are based around a phenolic/composite tube that will reduce the amount of heat that gets transmitted to your hands. They also come with nice little foam sleeves that further reduce the heat transfer. Neat idea, eh? BTW, once I get the pens in I'll test them out and report back on my findings.
I'd like to hear what you all think about the pyrography on this bowl. Too little? Too Much? Just right? Positioned just right? Wrong place? Tell me what you think.
Thanks for viewing.
See ya around,
My ugly mug
Dominic
Re: Small cherry bowl with pyrography
RevDoug
>Looks pretty nice Dom. I would have thought that you would want the curved lines burned a bit more. However, the design is great and well balanced.
Turn 'em round,
John Scheideman
>Very nice. I like everything about it. The shape is good, the lines are well placed, balanced with the shape of the bowl, and look very professional. Great job!
John
Molly Winton
>Very nicely done Dom. From this photo it looks as if you've done well with even burning of the lines. I know this can be one of the most challenging parts of burning when first starting. I think you will be happier with your lines when you use the skew-type pen. Now that you've got the taste of wood smoke I predict much more to follow.
Tom Storey
>Love it Dom! Question on technique, How do you set up the indexing for the burn lines? I could probably make a similar pattern but the final line would probably be either too far of too close to the first?? I know, once you tell me...DUHHH..but be danged if I can come up with it just now>
Thanks, Tom
Very Nice!!
Stokes
matt overton
>nice piece Dom, I like your work. I have about 10 of Pat's pens. I think they are top quality. If you are thinking of buying any, let me know and I'll let you do a test drive, I'm just up the road in Wrightstown. I'd like to see some of your work in person someday.
Thanks for the postings to keep me hoping that I too will get back in the shop more often
Cyril Griesbach
>Very well done. I like the placement, size and style of the ring. I'd prefer the interion lines to be darker.
Cyril
Wrightstown!
>Thanks for the compliments!
You wrote:
".....I'm just up the road in Wrightstown....."
You're kidding! I was just in Wrightstown 10 minutes ago. I had to go to the bank at the intersection of "5 Points" (Rt# 232, Rt# 413, Cherry Lane)
Since you're local, I'm assuming that you're a member of the Buck's Woodturners? If so, maybe I'll see you at the next meeting on the 26th.
See ya around,
Dominic
Thanks, and I agree
>Thanks for the compliments.
And I totally agree that the interior lines could have been made deeper/darker so that they would stand out more. Unfortunately the width and style of the pen I used to burn those lines made it extremely difficult. Pressing harder just burnt the wood. That's the main reason I ordered those new Optima Skew pens.
See ya around,
Dominic
Thanks Molly!
>Molly,
Thanks for the compliments. Like I said, I really appreciate all the help and advice you gave me. If by some odd chance you ever need some mechanical engineering or machine design advice, drop me a line. I'd be glad to return the favor.
I really can't wait to try out the new pens. I sure wish they would get here! :>) USPS Tracking says that I should get them tomorrow or Monday.
My next pyro experiment will be on a platter. I'm thinking of combining texturing (with my Sorby wheels), with some pyrography.
See ya around,
Dominic
Hi Tom
>Tom,
You asked about the template I used and how I was able to index it to make the lines a certain distance apart.
I could tell you that I measured the circumference of the bowl, then divided that up into an even number of spacings and arrived at an appropriate angle. From that point, using the outer diameter of the opening, I converted the angular measurement to a linear one and used that as my spacing. I could, but then I'd be LYING! :>)
I made a template that was cut so that when laid against the top of the bowl, it would fit the curve around the mouth. It was wider than the spacing between the lines. I then drew in the curve free hand and cut it with an razor knife. The I made a hash marks on the template about 1/8" - 3/16" apart. Using the template, I drew the first curve with a pencil, then I moved the template over, matched the drawn line up with the hash mark, and drew the next one. As luck would have it, the spacing worked out perfectly. If it hadn't I would have adjusted the last couple lines accordingly.
I've attached a photo of my template. I hope that helps.
See ya around,
Dominic
Thank you all for your kind words
Re: Wrightstown!
matt overton
>I've been promising myself that I'd get to a meeting and join bucks woodturners but I run Troop 74 and our meetings are on monday nights.
You might just be the impetus to get me there soon. Yea, you passed by on your way home. I'm on Penns Park Rd. across from the school. ....I'll see you in the the neighborhood
Keith Tompkins
keith tompkins
>Very Nice, Dom. I like the positioning of the burning, accents the bead but doesn't compete with the form.
Thanks Keith!
OK Neighbor
>I can't seem to make all the BWT meetings either! Mondays are a busy day for me (and "Heroes" is on at 9:00pm!!).
You should try and make one of the workshops offered by BWT. The last one was Don Derry and it was hosted by Dave Hardy at his shop in Sellersville. It was worth a heck of a lot more than the $30 I paid! If I get a notice, I'll pass it along to you.
BTW, keep and eye on that row of Osage Orange trees near Sacketsford Road. I think some of the bigger ones are tagged for cutting!
See ya around (literally),
Dominic
