General 260 HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bowlman
>Ok, I have a really urgent question. Do any of the General 260 owners out there know what to do when the magnetic overload feature kicks out? I pushed the red button on the back but nothing happens. When I press "start" I hear a "click" like it wants to start but something prevents it. (I then hit "off" just to be on the safe side.) I am right in the middle of a 3 piece commission and this situation has me really bugged. The lathe is 25+ years old and was purchased through Rude Osolnik. The instruction manual is a joke.
HEEEEELLLLLLLLLLLLLLLLPPPPPPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!!!!!!
Re: General 260 HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Dick Hines
Dick Hines
>Try unplugging the power for few seconds. It may just have to reset it's brains.
bowlman
>Done that ... let it set for over 30 minutes. Same "click" but no go at the spindle. Thatnks for your post ...
RevDoug
>I know it sounds dumb, but did you check the spindle lock?
Turn 'em round,
bowlman
>yep checked the spindle lock ...
Jerry from Lapel In.
>Dick: lossen the belt and try again . This should tell if it's the motor or something in the lathe drive train. If you need you can bring your project up here and finish them,let me know.
Ed in Leaside (Toronto, Ontario)
>The "click" is telling you that the coil is actuating. Therefore there is power at the switch. Did the overload actually trip or did the switch just stop supplying power to the lathe? It's possible that, after 25 years of use, one of the contactor's tips has burned out. This is easily checked with a voltmeter.
Re: General 260 HELP-Change switch
georgetroy
>By pass the magentic switch. I had a electrican change my 20 year old machine switch almost immediately. No trouble there after. GT
adrien
>Does the lathe have an electronic speed control? I have the full documentation for that somewhere in my shop, could fax it to you if that would help.
bowlman
>not electronic variable speed ... the older "Reeves" drive.
Bob Fawcett
>Dick,
disconnect the power and loosen the belt. Make sure you can turn both the spindle and the motor shaft and that they turn freely. If either one does not turn freely you found the problem. If they are both free check the motor switch.
Does the motor have a start capacitor? If so see if you can get a replacment. Imdustrial supply, electrical supply, or AC supply may have one. doesn't have to be exact except to mount. The values should be on a label on the unit.
Bart Rhoads
>Just a thought but can you rewire it by passing the switch and go directly to the motor using the breaker for the start switch just for trouble shooting?
Steve Kubien
I've got a General...
Steve Kubien
>...bandsaw and any time it has tripped up I have had to reset the breaker panel (conveniently located in the shop area). Unplugging never helps but restting the breaker does...even though the breaker itself has never tripped!
No, I'm not reall good with electricity. Good luck.
Steve Kubien
Re: I've got a General...
Bill Howatt
>If unplugging doesn't help but resetting the panel breaker does then I say the panel breaker has tripped but is just not giving an indication of being tripped.
Next time it happens measure the voltage at the bandsaw outlet. I bet it is zero.
Bill
Steve Kubien
Measuring voltage
Steve Kubien
>I assume this involves using a volt meter? Sounds technical to an electron-o-phobic.
Steve Kubien
Ajax, Ontario
Trouble shooting
jeff myroup
>BowlMan,
The first thing you need to do is check the switch. This is easy. Get a volt/ohm meter. You can get these pretty cheap, for about $20- 30.00. Check the continuity of the switch. If you are not familiar, it is the function that causes a sound when the meter leads are touched together. Check the meter for a beep. TURN OFF power at circuit breaker or unplug, locate the switch terminals. Place the meter leads across the switch. Make sure switch is on. If it beeps then switch is good and making contact. If it does not beep, then switch is not making contact. If it is not the switch, there are a couple other things you can check, but I would need more info from you. I am not familiar with the general 260. Let me know if I can be of help. Some pictures would be very help full so we could figure this out.
Jeff
Re: Measuring voltage
Bill Howatt
>Some of us don't understand how the others in this world manage to get by without a voltmeter! :)
If it is a 120V bandsaw you could just plug a lamp into the outlet and see if power is there.
Bill
jeff myroup
>The magnetic indution testers are awesome you dont even need to break the ciruit or plug anything in. just place it near the cord and push the button. If it lights and makes noise you have power. I don't know what I would do with out my meters.
Jeff
Dick Hines
Dick Hines
>I did not see in any of the post rather your lathe was 110 or 220. If it's 220 you have have lost one 110 legs. I had that happen once and my every thing in the shop that was 220 was doing strange things.
If you are useing 220 be care full because when you lose a 110 leg sometimes there will be power on the netural.
Good luck.
Juergen
>If power is OK I suggest you disassemble the switch. Best case you have some debris in the switch which can be blown out. Worst case one of the contacts is fused or oxadized. If it's the former clean and reassemble, if the latter replace the switch. Cost about about $35-45. I had dust in the switch on my General.
bowlman
>Thanks to all for your advice. I have printed the responses for my electricican to see. He will be here around noon Saturday (today). I even called General in Canada to get advice. Their advice was the same as yours ... check the breaker (its a "quad" whatever that is). If bad, replace. Then check to insure switch has power ... 220 volts of power. If bad switch, replace switch. Third, check the motor capacitor (starter). If bad, replace. Next check the magnetic overload. If all this fails, I may need a new motor. Since this is just a 1 HP motor, I may take this opportunity to put in a 2 HP motor in.
Again, many thanks. I sure hope its simple, fast and cheap. Guess I better get some of the voltmeters and magnetic induction thingies, hm?
