We value your privacy.
>I'm really getting tired of my bowls going out of round or cracking while in the drying stage. I have used all the well known options such as dishwashing detergent, brown bag, and simply anchorseal and air dry, all with limited success. I'm in the planning stages of a kiln. Hopefully I can get blanks to a mc of about 10% and not have this problem anymore. I have bought a heating element, and fan, but have yet to find a thermostat. I'm thinking of an in-line unit with a digital readout. Any suggestions?
Sorry I cannot help with your quest but your post raises a question to me. Are you going to use this kiln to dry blanks which haven't been turned yet in any way or is this inteneded to be a way of speeding the drying of rough-turned pieces? Interesting idea either way. I will be following this thread with interest.
My general thought was to cut my own blanks from green logs I have available. I would then kiln dry these blanks and turn bowls and such from the dry wood. I got the idea from the link below.
>I'm wondering why you are having so much trouble with your blanks. I rarely, if ever, lose a blank. Not that I'm bragging, but rather hoping to figure out what your problems are. I've noticed other people on this site with the same problems as you.
Lets start with anchorseal.
Do you coat the whole bowl or just the end grain?
Once painted, how do you store the blank?
Also
How long did the log sit before you rough out a blank?
What type of wood do you have the most problems with?
>I'll add to Ron's questions. How long do you let the log sit between cutting and sealing. Do you split the logs at the heart. I find a lot of problems are because the log is already splitting. Many cracks you can't even see until they show up while turning.
When you store the bowls is it in a dry hot place? I put mine on the floor of my garage where there is little air movement and they pick up moisture from the floor. After a month or so I move them up to the shelves. I coat the endgrain only unless it's a fruit wood or I left a limb knot in. Then I will coat the knots, the lip and bottom as well as all endgrain.
>Most of my wood comes to me via tree surgeons. I have an area maybe 50x50 designated for them to drop wood off. It may be months before I cut the log to length, then I'll cut it lengthwise, down the pith. I then take the half log to the bandsaw, and rough out a blank, the pith side being the top of the bowl. Then I turn it on the lathe to 1" to 1-1/4" wall thickness. This is where I have been experimenting. I will either soak in LDD for 48 hrs, and leave set on a shelf for a few weeks, or seal the whole blank with anchorseal and leave on the shelf for up to a year. I will also put the unsealed blank in a paper bag and store for up to a year.
I'm not saying I loose alot of blanks, but I sure don't have the success rate I hear other guys have.
I live in Childress, TX, and I've also just finished making a kiln from an old refrigerator, and I've just started drying my roughouts in it. It's hot and dry here, most of the year.
I have another old refer that I store blanks in before I turn them.
Email me, and I'll give you some particulars. Also curious where you got the name... :o)
>Dave I have been using two upright freezers for about 7 yrs now. I use freezers because with a refig you lose part of the space because of the freezer space. It has a thermostat that I purchased from Tek Supply that controls two 75 watt light bulbs. It has a double plug on the end and you just plug in what ever you want to control on one end and plug the other end into a power supply. teksupply.com STk #CR2045. They are on sale now for $44.95 This will maintain a temp of about 110 deg. and takes about three weeks to bring a full kiln down to about 6%mc. I will lose a bowl once in a while but I figure on that when I fill it up. I will turn my blanks like you said and put them directly in to the kiln when I finish roughing them. No anchorseal, alcohol, or soap.
>Addressing your original problem with the blanks cracking and warping. From my experience, if the blank has any significant part of the pith in it, it will invariably begin to crack starting from there. I suggest not splitting a log down the middle. Instead make an extra cut so you have a thin slab with the pith enclosed in it and two half-logs.
I assume every blank I turn will go out of round. That's why I twice-turn most of my bowls so they will be perfectly round. I did a once-turned elm recently which dried mostly in the freezer. I can visibly see it out of round, as I expected, but it's part of its 'personality'.
For the record I soak in LDD overnight rinse off, and dry upside down in my dehumidified cellar without coating or bagging. Virtually no significant cracking (unless it was there to start with and I CA it after roughing).
>I made a kiln out of an old upright freezer, 2 light bulbs, a dimmer switch and a small bath room vent fan. I use the fan to circulate the air in the kiln and have a 3 inch hole in bottom and a 3 inch hole in top with a piece of metal plate with a screw in one corner to act as a damper. I control the temp with the dimmer switch and damper. Start out the drying slow, you will actually have the inside sweating - then over a period of a couple or 3 weeks bring temp up to about 110 - 120oF and start opening up the damper to allow the moisture to escape. I check the temp in mine at least once a day and sometimes twice. Near the end when my moisture meter shows that the blanks are getting dry I will raise temp to 130 - 140 to make sure and kill insects. I have read that temps above 160oF will cause damage to the wood. PM me if you need more details - I got tired of turning things twice and just prefer dry wood to start so I started drying my blanks before turning. I do wax the ends heavily and remove the pith before they go into the kiln.
I am curious as to haw a kiln would stop wood blanks from warping. I have little cracking loss but assume every blank will dry oval. The ones I lose to cracking are those I know will likely crack before I set them to dry, but they are worth the risk and the two cents worth of Anchorseal to try.
>Just remember that the whole purpose of a kiln is to dry the wood out uniformly throughout its whole thickness. Cracking and splitting occurs when part of a piece of timber drys faster than the rest.
>I think I probably should have explained better. I plan on changing my whole method. When we turn green blanks to bowl shapes, we then set them aside to dry,no matter what method,LDD,alcohol, air dry, whatever. It is at this stage when the rough blank goes out of round, warps, or whatever it wants really. We wait for months and months to complete this process, only to put the bowl blank back on the lathe to try to turn it back to some assemblence of round. Why not skip this stage and start out with a dry blank fresh out of your own kiln? Put the dry blank on the lathe, turn it, finish it, and sell it.
>I think that the only way to keep things round is to boil them. Then there is very little movement. I have heard of blocking and banding blanks, but would worry about over stressing the wood.
>Dave, I agree with your idea. I'm drying some blanks right now, in my homemade kiln. Don't know how long it takes to dry one, yet, though, but when it's dry, I'll know it.
I'm just hoping that while they are drying, that they won't crack like they do just sitting on a shelf. What I'm hoping is that something in the way the heat affects the drying procedure will keep that from happening. Who knows? It's worth a try, anyway.
>While in theory that would work, the thicker the blank, the longer it takes to kiln dry. When you rough turn a bowl to %10/diameter, a 20" bowl is only 2" thick. If it is 8" high, you block to dry is 20x8. Even if the outside was dry, it would be considerably more so than the center. Even if it were dry all the way through, when you cut into it, you are releasing stress. The stress itself will make it warp. Not as much as if it were turned green and dryed, but it will still warp.
In addition to that, the wet wood will turn (cut) much easier than the dry wood and with far less dust and smaller particles than the dry. While I am an experimenter (assperiments in my house) at heart, I have accumulated enough dry roughed out bowls to where I would only need a kiln to do commissions where they want it faster.
