Stuck chuck - Not quite
nailshooter
>I had the same problem with mine the first few times I changed the jaws out. Finally, one time I had one side fo the jaws that just wouldn't budge. I dont' remember which jaw set it was, but it was as if the screws were welded in position. I even resorted to soaking the whole chuck "break free". No help.
Called the group I bought it from (KMS tools) and they told me that the tolerances were such that it happened from time to time. Take a look a the screws, too. They are anodized or coated, and they are on bare metal when installed. They were unable to help.
I finally needed the other jaws in the chuck so bad that I put the chuck in vise, hit with some break free and muscled out the screws. I thought for sure the hex key would break, but it didn't. I figured if the head(s) broke off, I could either drill out the remaining stub and grab what was left with vise grips after removing the jaws, or I would get lucky and they would shear at the bottom fo the head. However, the simply chirped when they broke loose, then came out. I did slightly strip one of the screw heads, but purchased one to replace it from KMS. Those screws are their design, and it has to be one of theirs, so if you order get a couple extras for "just in case".
Now I put a tiny bit of grease on the tips of the screws before assembly if I change the jaws and make sure not to overtighten. No problems since then.
Robert
