"The Sanding Solution" - experiences?
leppikallio
>Yep, I received my "American Woodturner" yesterday...
Anyway, does anyone here have any experiences with that "the sanding solution" from "the sanding glove"? And what interests me most are you really able to sand with it inside hollow forms and how big opening does that require? With 1" pad it shouldn't need that big opening but... It is indeed expensive and I know there is other sanding solutions as well but passive sander with articulated head sounds almost too good to be true...?
Re: "The Sanding Solution" - experiences?
Ric Taylor
Ric Taylor
>I use both the sanding glove and a passive sander, and they both have advantages at different times. I use both of them frequently, as well as several other methods and tools for sanding. There isn't any one way of sanding that will work in all circumstances. Just as a turner needs a variety of cutting tools, a variety of ways to accomplish the sanding is also needed.
Ric
ReYou could try a trick out of Terry's book
>for your hollowforms, that is. He took an old motor and "stepped" it down in speed with a couple of pulleys. He "chucks" up his piece in the assembly and puts small pieces of gravel inside. After a while (sometimes overnight), he pours it out and puts finer gravel inside and runs it again.
I've not tried it (or hollowforms either). His pieces look fairly smooth and even on the inside.
Leppikallio
>What I infact would like to know is that how good it is for sanding insides of hollow vessels and how big opening does it require. That passive sander I mean.
Re: ReYou could try a trick out of Terry's book
Leppikallio
>I bet that is the way to go in many cases but I think that won't be that good way to get rid of those possible "humps and bumps" inside vessel as rocks or abrasive material will work equally everywhere... however with sanding it could be possible to smooth inside perhaps further?
>Shoot Terry Daniel an email and ask him. I'm not into hollowforms yet. You can find his postings earlier in the year (January or so).
Allen Neighbors
>I've got a tumbler I made after seeing Terry's in use at the GA Gathering. It works surprisingly well at smoothing the inside of hollowforms that you can't get anything else into. I use sharp granite gravel in mine... anything that will go into a 1/2" opening.
It does not smooth the harder grains as well as it does the softer grains, therefore, the softer grains are lower and harder grains are higher. But if you can't put a finger into the hole, what else is there, and what difference does it make?
I got some carbide in the mail from Bill Turpin, but I haven't got a chance to try it yet. I think it's going to make a big difference.
