REAL MILK PAINT
Photo tip for spindle contest
>This shot doesn't need to be great, just sharp and clear with no harsh shadows. There are 2 really easy ways to do this. First pick a contrasting background. In this case I used a piece of cardboard. Don't make the piece too small. If you want us to see the details fill the frame. If your camera won't focus close enough back off and crop it in the computer to make it larger.
If your using an auto focus only camera make sure the edges of the piece fall within the focus area.
If you must do it handheld try raising the ISO setting so your shutter speed won't be to low. Most blurry photos are because the camera is handheld at to slow a shutter speed.
Lighting. Shoot at sunset or sunrise out in the open. If you have harsh shadows shoot earlier or later. As the sun sets you'll see the shadows on the piece get softer. Of course this will require longer shutter speeds. If you shoot outside on a cloudy day it may solve both the shadow and the shutter speed problem.
Indoors. shoot next to a white subject with the lights on the other side. I placed the piece on the cardboard next to my refrigerator. The light is overhead and behind me. The white refrigerato bounce some light back into the shadows and makes a nice shot. You will need to set your white balance to match your indoor lighting. In this case in was tungsten lighting.
Re: Photo tip for spindle contest
Outdoor shot at sunset
indoor shot
Earl Kennedy
>Ok John I give up.Where is the photo????
refrigerator lighting
>This is how I shot the photo using the frig as a reflector. It's a little green because my frig isn't perfectly white. It's slightly green. A piece of white poster board or white paper would have worked better as a reflector. I have white ceilings and light walls so this method works. If you had red or blue walls the piece would be a little red or blue.
Lacey thought this was a toy for her so she was patiently waiting for me to give it to her.
Your too fast earl :)
Re: And don't forget that .........
Jamie Donaldson
>... shooting in the shade of daylight will result on a blue cast due to the high UV light. Some cameras have a color balance setting for shade that works well, just as the tungsten or incandescent settings work better than daylight for most indoor shooting.
Re: indoor shot
Jorge Castaneda
>Nice crisp detail John!
Steve Kubien
Holy smokes!
Steve Kubien
>You got each one of those identical! How'd you do that?
Runnin' and duckin!
Steve Kubien
