Have a question? Ask Woody!
$6500 1/2 hp Electric Motor
georgetroy
>We are getting a new high efficency furnace and air conditioner installed today(Rheem)Kansas rural prices. I pulled the motor and squirrel cage. The motor looked like brand new, complete with wiring and shaft. Motor could be used on a mini lathe or other small lathe. Specs are 1/2 hp and 1725 rpm, 1/2" or 5/8" shaft mfg. by Emerson electic. I will use the motor for a flexible shaft with Drill chuck. Or it can be mounted solid for a small polishing and buffing wheel. Or whatever else it might be used for. I don't need the squirrel cage, but don't plan to throw away. Made my day and now that motor is worth $6500 in funny money.
Re: $6500 1/2 hp Electric Motor
RevDoug
>Sounds exactely like what I used for my Beall buffing stand. Built a simple stand with 2x4's. Mounted the motor and a switch on the top with the motor sticking off the end. Added the arbor adaptor that came with the Beall system and I'm now off to the races when it comes to that part of the finish process. Sure beats Minwax Finishing Wax and hand buffing.
Turn 'em round,
Just did the same thing an hr. ago.
Eddie Pacheco, San Jose, Ca.
>We're getting a RUUD heater and A/C unit installed. I saw my old heater on the driveway and yanked the blower/motor assembly before it got carted off. Not really sure why I went with RUUD and not a Rheem or Bryant, as I had a choice. The original one was a tract home Day & Night and it lasted 29 yrs. and was still working when it was taken out today. So we'll see if this new fangled 'puter controlled replacement can rack up the same worry free mileage.
Stuart Johnson
>Is the motor 110 or 220? I had our motor saved when we got a new furnace and it turns out it is 220. I'll probably go ahead and build an air cleaner using it someday but I would have preferred 110.
Re: Just did the same thing an hr. ago.
>Eddie, Rheem and Ruud are the same. Manufactured on the same lines, one painted green and one Brown. Parts are interchangable. Carrier, Bryant and Day Night are all made by the same comapny. The anothe one too, Payne I think.
You also probably have 3 speeds :-) !
Clem Wixted, Jonesboro, AR
georgetroy
>If the motor has 220 that is ok also. No problem. I need to check that. Thinking about a light switch with a variable speed, also need to check and see if that is possible. GT
