Skew Chisel - how do you sharpen yours?
Joe in a Cleveland suburb
>Hi,
Can you tell me how you sharpen your skew chisels? What procedure and tools do you use?
Do you grind, sharpen, and hone the same as you do your nice plane irons or is that sharp not necessary? The goal is to have a skew ready/sharp for use on some cherry legs.
I've been practicing on pine scrap. Now I think I should think harder about the sharpening end of it.
Thanks,
Joe
Re: Skew Chisel - how do you sharpen yours?
>I don't know about anyone else. My waterstones are always "at the ready" in my old kitty litter bucket. So I use my waterstones to about 8000 grit. The sequence usually goes 1000, 4000, 8000 for me. I rarely have to use my coarse stone. Brian, a friend of mine, uses small diamond paddles for his, followed by his honing stick.
John Kyler
>I grind and then polish on a Cratex wheel.
I use a diamond hone in between to keep the edge.
Greg Haugen
>First of all, a skew can NEVER be too sharp. The sharper the better.
This is what I've learned from Nick Cook and Alan Lacer. It's what I do. It's not the only way.
With that said I have four skews. They are ground on a dry grinder with a light touch. From there I hone four surfaces with a fine diamond hone, the two sides, the top and bottom. The top and bottom to be sure the toe and heel are as sharp as possible. That is a Alan Lacer technique. At this point I can use them. But I often do power hone them on MDF wheels charged with White Diamond compound. My wheels are setup on a MT2 arbor so I put them on the lathe and flip it into reverse, if you don't have reverse stand behind the lathe will also work. Never hone this way with the wheels "rolling" towards you. Power honing will create a "mirrored" polished edge. "Scary Sharp" is a term for this.
If I'm traveling I hone/sharpen with a medium grit India oilstone by Norton on the bench. This is a Nick Cook technique. I then can also hone with with a fine diamond hone.
Hope it helps,
Greg
eaglesc
>I sharpen the skew the same way I sharpen everything else
Diamond stones.
I wouldn't sharpen my pocket knife on a grinding wheel, why a turning tool?
So the answer is...
>Yes. You guys sharpen your skews to a nice polished surface like I would my plane irons.
I'll try my water stones. Or maybe sandpaper - I have a bunch left over from trying the 'Scary Sharp' method a few years ago. I don't want to buy more sharpening stuff right now.
Thanks folks!
Joe
>I do like Greg. I hollow grind the bevel until it almost reaches the edge. Then I use the medium, fine, and ultrafine diamond paddles and then I have a leather strop that I hit it with. I can usually usually sharpen with the ultrafine and strop most of the time. As the edge gets thicker I have to go to the fine, ultra fine and leather. Eventually Ihave to go to the medium and then I get tired of doing that and go back to the grinder.
Re: Mine never get dull- they stay.....
Jamie Donaldson
>... in the tool chest where they can't scare me!!!!;-))))
Re: So the answer is...
tek-Brunswick, Ohio
>I use a fine diamond hone and then a white ceramic stone. I'm sure your method will work also. If you can sharpen a plane iron well you can sharpen a skew chisel. There are a few different camps on the shape of the edge and the bevel. I like the traditional straight edge. I tried the radius edge like Alan Lacer uses and found out I like the straight edge better. I use a hollow ground bevel. Ernie Conover insists a flat bevel is better and Eli Alverso (SP?) uses a convex bevel. If you find you are comfortable with the shape and bevel you are using stick to it.
>Jamie you need to study under a true Ninja Master. Once you've found enlightenment you will be able to handle the skew, grasshopper.
AMEN
robert davis
Grinder & felt wheel...
Peter Teubel
>From a production turner's point of view, time is money...including time spent sharpening. When I leaned the skew, I picked up techniques mainly from Richard Raffan and Alan Lacer videos. Alan showed me the basic theory and techniques, while Richard showed me speed and finesse.
Among other things Alan promotes honing with a diamond stone. He says in his video that one can touch up an edge by honing in 30 seconds or so.
Sorry, that's about 20 seconds too long for me. Plus the fact I can't seem to develop the hand-eye coordination to hold both the tool AND the stone at the correct angle(s).
After grinding the skew (usually once per turning session), I take it over the a zam-charged (the green stuff) hard felt wheel mounted on a 1700rpm motor and can hone/polish the edge to shaving sharpness in 10 seconds (5 per side). I can repeat the honing process many times before I have to return to the grinder.
For me, this process makes the skew sharp enough to SCARE the hairs off my arm...
My side hurts from laughing so hard
Greg Haugen
Oilstones
Jorge Castaneda
>for a major sharpenning and honing, diamond files for touch ups.
Jorge
Grinder
Ron in Drums PA
>100 grit wheel than right to the wood.
JanManuel
>I've seen folks cringe when I describe how I sharpen a skew....but you make do with what tools you have available.
I "grind" them freehand on a 6"x4" belt sander, then give the edge a quick honing on an 2 sided stone. I touch up the edge many times with the stone before I have to grind again...I keep a 100 grit belt on the sander.....
dwr
>By hand...
6" grinder...
better finish than a jig...
I LOVE my skews...
Would NEVER turn without them...
Steve Kubien
Close to my method
Steve Kubien
>I've got one of those 1" x 42" belt sander thingamadoos and just love it. I keep a 120 grit zirconia (sp) belt on it and have a 15 micron belt for heaven-knows-why hung up on a hook. That 120 grit belt does all of my sharpening for turning tools...gouges, parting tools, skews. Can't say enough good things about the set up. Best thing is...no jigs. Free-hand everything and get back to work. I tend to hone my skews with a 1000 grit waterstone to remove the burr, sometimes.
Cheers,
Steve Kubien
Ajax, Ontario
Re: Why do they have to be hollow ground?
Dick Anderson
>Dick They don't have to be hollow ground. The main reason people hollow grind skews and hand chisels is that it takes much longer to sharpen a flat bevel. With a hollow ground edge the diamond hones or whatever you want to use on have to remove a small amount of metal to get the edge really sharp.
The hollow ground has 2 high points, the edge and the lower end of the bevel. Set the diamond hones on these and take a few strokes until you feel a burr on the back side. Then flip the skew and do the same until you feel the burr. Change grits and do it again. It takes me about a minute or two total to sharpen the skew to a razor edge. It takes me much longer to sharpen a flat bevel.
I tried a flat bevel and didn't see any advantage. There does seem to be an advantage in control of cut on my hand chisels so I do leave those flat.
Dick Anderson
>Hi John:
Thought I would raise a response with that question. I grind my skew (1-inch with rounded edges) on an 8-inch wheel in a freehand manner that produces a convex surface (bevel). I then hone with a fine diamond hone and strop using a fairly stiff leather strip attached to a board and charged with zam. I will strop fairly regularly and occasionally touch the edge with the diamond hone.
I find this grind more user friendly since I can use more of the cutting edge up to the long point rather than keeping the cut in the lower half (between the middle and the short point) of the cuttng edge. With the hollow grind there seems to be more of a danger in getting a catch if the cut is made in the upper half near the long point.
I find it easier and quicker to keep a sharp edge on the convex bevel than on the concave bevel when using a flat stone or diamond hone.
My oval skew is used only as a negative rake scraper on hard woods like the red mallee and brown mallee burls, which will tend to chip out even with very sharp gouges. I personally don't like the oval skew, but understand why many turners do.
Just another way of doing things that may not work for everyone.
Dick
>Dick I'm going to make myself a skew with a convex bevel if I have any metal laying around that I can do that to. In interested in see how it handles. I have difficulty seeing how a convex bevel would be more user friendly above the center line than a flat or concave bevel, but then I'm probably thinking too much and need to put the metal to the wood.
Since I'm doing a skew demo in 2 weeks I should probably be able to answer this question definitevly and making a tool and trying it is the best way. Besides it's a chance t make another tool.
Re: I know from sad experience .....
Jamie Donaldson
>... that a convex or rounded bevel is more "aggressive" and prone to catches when making planing cuts, and harder to control when rolling beads. The problem is due to a much shorter bevel near the cutting edge- you go from rubbing the bevel to a full cut in an instant! The longer bevel gives a user a better chance to sneak up on the cut with more control.
Re: Why?
Ron McKinley
>Why would anyone want to sharpen a skew? It's only purpose is to open paint cans isn't it? .........Ron
