new router carved box
>This is my latest box that is carved with the router. It is Ash and Purple Heart. Purple heart isn't the best wood for this because it's brittle but I tried it anyway. It seem to work OK as long as I took light cuts.
Re: new router carved box
photography made simple
>Here is how I shot the piece in my shop. I used 2 Moffet lamps. One was place closer than the other one to make one side brighter than the other. This also created a dark side with a shadow. I used the second light to light up this are. Then to add some more detail and lighten the shadow more I use a mirror up above and the the left to bounce light from the right hand light back onto the dark side of the box.
I set the white balance on the camera to the Tungsten setting. I also stuck a black bag on the back left corner to keep the "Blue" sunlight from leaking onto the set. I missed the focus a hair. I used f8 with an 80 to 200 zoom and my depth of field was pretty shallow. I missed the focus a hair. I have trouble focusing my personal camera. The Nikons I use at work are much better for my eyes. Of course I used a tripod and cable realease.
The background is a piece of seamless paper. I cut it down to 2 feet wide. I used rare earth magnets to hold it to the lathe and hung the background from pipe I buried in cans full of concrete. These make handy stands that I use for everything from holding air hose to holding lights and backgrounds.
Mike Stafford
Mike Stafford
>They just get better and better, John. This is quite lovely and I imagine time consuming to complete but the results are worth it. A beautiful piece!
Re: I really like the finial design John.
Jamie Donaldson
RK in Milwaukee
>Hey John,
A Goyen Rose Engine lathe sold Saturday night on Ebay for a little over $65,000. Were you one of the bidders? You know you want one...heh, heh, heh....
Great looking box.
Ron Nelson
Ditto
Ron in Drums PA
Very nice,
Eddie Pacheco, San Jose, Ca.
>Does your lathe router jig have a provision to follow the contour of a shape? It looks like the routing follows the spape. I may have missed a post where you described this aspect of it. Very nice job.
The brief photo lesson was good too. Sadly, a lot of that info went over my head.
Doug Thompson near Cleveland
>It sure does look good, I like how the coves disappear at the base. Nice photo booth.
Re: Very nice,
>Eddie I cut out a pattern for the router to follow. I stick the pattern to the router table with double stick tape. I can adjust this anyway I want. In this case I made the shape the same thing as the box. Then made a seperate pattern for the lid.
>Ron They wouldn't take my house in trade. I would have had to live in the shop but I'd have a really nice lathe.
>Mike They go surprisingly fast. Of course if you made more than one so you could use the router patterns over it would go really fast. Still I don't know what I'm going to ask for these. I'll probably get with my gallery owner we'll hash over the price. I know I have more hours in them than I should because these are learning experiences.
A fellow artist and I once decided that a well used coke machine makes more per hour than we do.
Thanks Jamie and Ron
>Doug this was turned entirely with your spindle gouge, except for the 2 parting cuts. It handles differently than my other spindle gouge. I'm guessing it's the thickness of metal below the cutting edge. It requires a slightly different roll. I assume it's because the edge is higher from the pivot point on the tool rest. I'm really starting to like this gouge. I usually have to sharpen after hollowing a box like this, especially ash. Since I hollow with more of scraping action it really dulls an edge. I turned the finial without sharpening and it still took that fine a cut.
Chris in KC
>John,
Have you already posted a message as to how you accomplished this? If so, I am missing it. I would love to know your technique and what the jig looks like. If it wouldn't be too much imposition, I think others would appreciate knowing how you make these beautiful objects. They truly are amazing.
Thanks,
Chris
>Chris I just sent an article off to Woodturning Design covering all the details to make these things. Hopefully they will like it enough to run it. It's not complicated but gets a little wordy for the messageboards.
Jimiles-Charlotte, NC
>Coke machine! I love it - I will have to remember that one.
And: a coke machine dosen't mind sitting all weekend in foul weather at an art show!
Bob Moffett
Bob Moffett
>Very nice box. I'll be looking forward to the article in Woodturning Design.
Allen Neighbors
>John, this piece, and the others that you've routed, just absolutely fascinate me. The one tool that I feel like I'm missing in my shop is a router jig. I've copied everything that I've found that you've posted on it, and one day I'm going to give it a try.
I've got a lot to learn about form, first. :o)
Thanks for the inspiration!!!
>Allen Feel free to e-mail me if you have any questions. Once you start you will start to see what can be done and probably come up with your own designs.
Dale Cook
>This is very nice. I like how your top flutes don't line up with the center. You should have no problem getting published in woodturning design.I hope so I'd like to see it. Great piece.
Keith Tompkins
Re: Neato!
keith tompkins
Allen Neighbors
>Thanks for the kindness, John. I may do that.
