Jammed Quill in Tailstock
Jorge Castaneda
>Hello turners, my lathe is a Nova 3000,
Yesterday I was attempting to make a bunch of handles for my gouges, after finishing boring the first one, the quill is jammed, cannot make it turn taping it with a rubber mallet, not even with sharp raps.
I managed to get a small cylinder under the tihghtening screw, that fits into a keyway,( the cylinder is the key) now it can make a half turn if the keyway is facing down, 180 opposite from where it needs to be, if the keyway is where it shoud, the quill is jammed. I left word with Tim Geist, but no answer.
Anybody had this problem before?, how was it solved?
Thanks in advance
Jorge
Moaning in Stonington, a storm day and a crippled lathe, arghhh
Re: Jammed Quill in Tailstock
RevDoug
>Let's try this. There is a set screw accessable through the hole in the hand wheel. The hole needs to be at 12:00 to get to the screw. Remove it. The hand wheel keeper is in the slot on top of the tail stock, remove it. You should now be able to back the hand wheel off the quill. Place a block of wood against the outboard end of the quil and tap the quil out of the tail stock. Once out, you will want to clean all the debris out of the tail stock, realign everything in the proper orientation, and reassemble. I hope this helps. If not, maybe Tim will get back you soon.
Turn 'em round,
Jorge Castaneda
>Thanks Doug,
I'll try it right now.
Jrge
RevDoug
>Let me know how it works. If not I'll get my books out and see if there's something else we're missing.
Turn 'em round,
It Works!!
Jorge Castaneda
>Doug,
I owe you one, after doing what you said, I still had to use a chain vise grip to get it unstuck, I did back it too far last time used. Some dirt in there and awfully dry, I cleaned and will use some graphite grease or some molly if I can find it.
Thank you very much
Jorge
Looks like thre is enough day left to turn a certain platter.
No problem. Glad you got it broke loose.
RevDoug
