Shop made disk sander
Bob Fawcett
>I built this sander last week. Just an MDF disk glued to a block of hardwood and a plywood platform.
Bob Fawcett
Re: Shop made disk sander
Bob Fawcett
>The hardwood is tapped to fit the spindle. The hole is for a set screw I plan to add to prevent it unscrewing itself when I stop the lathe.
Bob Fawcett
>The platform clamps the lathe bed with a plywood block and there are 2 hardwood runners to help locate it.
Ron in Drums PA
>Great!!
Have you considered making a dust port in the base?
Allen Neighbors
>Bob, that looks really well done. Looks good on the Mustard Monster. :o)
Bob Fawcett
>I haven't used it yet as you might can tell. A dust port would be a good idea. Any suggestions?
Bob Fawcett
>thanks Allen.
Bruce in Saint John,N.B.
>A really slick idea Bob, I think I will put this idea on my back burner for a future project. Thanks for posting.
Ron in Drums PA
>Keep it simple
Turn your box 180 degrees so the opening in on the sandpaper side. Place the knob under the ways. Cut a 4" hole on the closed side (or whatever your dust collector accepts). Epoxy in a PVC pipe into the hole. Connect the dust collector hose to the PVC pipe and you are set.
Show us a picture when you are done.
Denis Putland from Saskatchewan
>A great idea and a nice job.
I do have one concern about using a hard wood face plate.
I have made and used many hard wood face plates and I find that they do not always remount to run 100% true.
It is probably due to wood movement and also the wood threads are not perfectly solid as in a steel face plate.
I think I would use a dedicated steel face plate for accurate remounting.
Just my 2 cents worth.
Denis
Bob Fawcett
>I cut a small amount of the threads out at the headstock side and turned the end flat so it seats against the flat of the spindle. I hardened the threads with CA glue. I have it marked so I can see where it seats each time. So far it stays in the same place. We'll see if it moves.
