Have a question? Ask Woody!
Willard Baxter 's Threading Machine *LINK*
Mark Kauder, Phenix City, AL
>Do any of you have/use the Willard Baxter Threading machine that my friends over at BestWoodTools make and sell?
Many of you know that Willard was a woodturning legend here in the SouthEast, that past away a couple of years ago from a brain tumor. The new woodturning studio at the John C. Campbell Folk School is named after and dedicated to him. I was lucky enough to see Willard himself demonstrate it, but at the time, I could not afford to buy one, and frankly based on what I was doing then, could not see the need for one.
Since doing a couple urns needing threaded lids, I now have the need.
Yes, I could learn to hand thread, and might some day, but right now, I am interested in opinions of this tool.
Thanks
Mark
Baxter Threading Machine
Re: Willard Baxter 's Threading Machine *LINK*
>Mark It's been on my list of wants for a long time. It's very precision made and has the option of taking different threads, of course that option costs more money. I've never been able to actually use one however. I have played with them and it's like working a fine machine tool.
I've looked at all the threading devices out there and I like that one best. for me it's either save up and buy one of those or build the one Al Crandal built.
I'm going to learn hand chasing threads just because I think it's cool. the advantage of a machine like Willards is that you can cut threads in almost anything even soft woods. You do have to harden the threads with CA. You can even make really small objects like Willards Acorn Earings that are miniature boxes.
Charles B. Watson
>Willard was a dear friend, and I purchased the threading machine several years ago. I used it a few times immediately after acquiring it to make boxes with threaded lids. It was set-up on a mini lathe, and worked just fine.
>Now that I have expanded my shop, I can have my Vega as my primary Lathe, and have my Mini setup for other things. This would be one of those things.
mark
Re: If BestWoodTools is making it, you can bet it
Al Crandall (N.E. of Indy)
>If BestWoodTools is making it, you can bet it purrs like a sewing machine. However, based on my first version of this design which was powered by a Jet mini lathe, I think the max rpm of the lathe is too slow for the cutter. It made pretty smooth threads provided you fed the work past the cutter at a slow rate. That is why I built another version which is powered by a router. 10,000 to 12,000 rpm cuts threads much better and cleaner. My suggestion is buy the Baxter machine and set it up in front of a router held in a shop made fixture. There will be a learning curve to the process, and you need to be able to remove the work for a trial fit and then repoition it exactly where it was so you match the thread lead and don't double thread the piece, but all that is easily designed around. I am now using a 1" diameter cutter with every other tooth removed.
>Thanks for the insight, Al. Yes, I appreciate the quality of the work of Best Wood Tools (can't remember their names for the life of me - I will remember as soon as I post, no doubt).
If I end up doing much of this, a dedicated station would make sense.
Mark
HOLD IT!! It's Sharon and Phil (?) not positive about his name.
Build Al's.
Ray Thompson - Middletown,IN
>It works great, you can save a buck or two, and you can keep your lathes freed up for other things.
Ray
O.K. Al Crandall...
Clem Wixted, Jonesboro, AR
>.. I'm intriqued.
Where are the plans for your design of a threading jig?
Clem
Victor
Pete Kekel - Kentucky
And Sharon. Super nice folks!
Gary Evans Tallassee, TN
Re: Here is the site for some pictures.
>Hi Clem. There are no plans as such, but our club web site has several pictures taken at the meeting when I debuted the contraption. If you open each thumbnail picture, I have added comments to the page detailing what is being shown. I can't think of any dimensions which are really critical, so just take the general ideas shown in the photos and run with it.
http://www.cicaaw.org/image/tid/105
Open these shots: 1379, 1380, 1381, 1376, 1377, 1378, 1373, and 1375.
Yeah, I finally remembered Sharon, Victor - thats
>Yeah, I finally remembered Sharon, Victor - that's it.
We need an IMDB.com for turning stuff.
Mark
