How unusual is this?
>Here's a shot of a poplar tree I took down yesterday. How unusual do you think this kind of figure is? And will these colors last once I turn it?
Cheers,
Re: How unusual is this?
Ron in Drums PA
>Really Nice
There is only one way to find out if the colors will last.
That is, send it to me and I'll keep tabs on it for you along with monthly updates.
Does that work for you?
Cyril Griesbach
>Ellis, it's unusual alright. My guess on the colors is that, over time, they will blend into an homogonous brown much like box elder will with time. However, looking at the bark on this...it just doesn't look like poplar to me. Looking forward to seeing a finished piece from this log.
Cyril
Mike Schwing from Md.
>Ellis, I see this in quite a few of cut poplars, in fact there are logs on my property waiting to become firewood that have this same coloration /pattern in them - these particular logs are no good for turning as the trunk was badly cracked otherwise they'd be turning blanks by now. I do not know what the cause is, nor how well the color retention will be, but I do know that around here that type of pattern in poplar is not unusual.
Ray Johnson
>Hurry and turn something from it. I would bet that we all would like to see some pictures.
Pete Kekel - Kentucky
>I've seen even more vivid purple colors in some Poplar logs and the end result is different shades of brown after an oil finish and some exposure to light. Some of the red staining in Poplar will stay longer, but in my experience the purple becomes brown.
tek-Brunswick, Ohio
>I've been a carpenter for 35 years. We use a lot of poplar for painted trim and door jambs. I see a lot of colors like this. Poplar can have green,brown, purple, or black steaks in it. I don't think that they fade much, but the cream colored wood will darken with prolonged exposure, and mute the contrast in time. Keep it out of the direct sunlight and the color contrast should last a long time.
>Thanks, folks. I've turned some purple poplar myself in the past and as Pete says, it goes brown over time. But this log has a riot of color going on. Maybe a water white finish and keeping it out of direct sunlight will preserve that. Only one way to find out... :-)
Robin Corell in Atacsadero CA
>I used to see those colors fairly often in pattern wood. the purples and to a lesser extent the greens are fairly light fast. We used to hate working the stuff with the extreme color as it often had a rather foul scent.
Robin Corell
I have absolutely.... *LINK*
Thad in Wartown
>...no idea, but I'd post on WoodWeb.com's sawing & drying forum and ask Dr. Wengert's opinion. He'd know what causes it, which could lend itself to knowing how to best work with it.
Hope this helps
~ Thad
WoodWeb's Sawing & Drying Forum
Denis Putland from Saskatchewan
>Hi
When I see a poplar with that type of coloring in my part of the world I can almost guarantee you that you will find worm damage or much less likely some other sort of physical damage in the past life of that tree.
Most of the logs with the colored wood is only suitable for fire wood due to cracks and rot.
But keep looking for those older dying poplars as there is some nice colored poplar if you catch it at just the right time.
You are very unlikely to find much color in a young healthy poplar tree.
Denis
Jim King
>This may or maynot be of interest.
Jim,wood id mihaly.htm
The development of color in heartwood is just the tip of the
iceberg, as it were, of the chemical changes that take place during
transition from sapwood to heartwood, but it is something that we can
easily notice and appreciate. The role of these chemical changes is to
make the wood tissue chemically protected and physically sealed for
durability and resistance to insects and fungi.
There are 200-300 secondary metabolites, chemicals other than DNA,
sugar, proteins and players of essential metabolism, in any plant
tissue, including wood. Heartwood is special in that there is no DNA,
sugar, proteins or nitrogen left in it since it is dead tissue. These
chemicals were produced as the last act of plant metabolism in these
tissues. They are the products of dozens of biochemical programs,
encoded in DNA, and they run simultaneously, sometimes competing, their
relative speed depending on environmental (including minerals, stress,
and pathogens) and internal factors (genetic program in DNA). The end
result is, depending on the species, is a more or less uniform or very
variegated heartwood color. But there are always at least some of all
the chemicals present. It is their relative proportion and distribution
that changes, giving rise to visible patterns of color, patterns of
fragrance and invisible patterns of chemical deposition.
Stress from drought, mineral deficiency, abundance, and most
importantly the constant attack by borers and fungus causes multitudes
of chemical responses in the wood and mostly this is what causes the
patterns. The color pattern is a visual snapshot of combat situations
and moving fighting fronts frozen for eternity at the time of heartwood
formation. Plants have a lot of chemical defenses that act like
immunity. Colored substances often tend to react with DNA, hence the
color in wood.
Minerals may contribute but not as much as the layman's notion.
Plants regulate what they take up by their roots and only few chemicals
can be taken up in excess.
When the defenses of wood are broken, spalting happens. Spalting also
produces colors which are a combined result of the sapwood and the
microbe, therefore more colors may be produced then what the tree alone
could produce, and this may be specific to a given location or unique.
Many fungus are colored themselves, most have melanin that appears
bluish or black, brown.
I use chemical fingerprinting to distinguish and classify samples but I
still use a microtome to make thin sections for microscopy when I
already have a guess. As I said, the information on wood anatomy and
plant diversity of the region is insufficient and spread between
hundreds of articles and books, so keying out a species is not
instantaneous to say the least. But I am better prepared for legumes
and
especially Dalbergia and Machaerium because I already have done the
literature research.
We should be mindful of the sensitivities of the local botanists and
should observe the local regulations. On the long term this study would
ideally benefit the local or national university in the form of
herbarium material and shared data, and should not appear as
exploitation. Just how to go about it should be sensibly worked out.
Pink woods: Truly clear pink woods are rare and therefore valuable.
Pink ivory is a deep pink wood, often without figure.
But even in Peru there should be some tulipwood (Dalbergia
decipularis),
which is streaked with pink. Then you have bloodwood (Brosimum) which
could be deep red or purplish pink, like your rainbow wood. I also
expect Simira, which is brick red in the heartwood, but neon pink in
the
sapwood or wherever you break the epidermis. Then Aspidosperma, which
in
Colombia produces neon pink with some yellow splashes.
I cannot immediately recall more. Most other woods are not pure pink.
Pure purple colors are also not common. Peltogyne is outstanding of
course. But queenwood is remarkable with its magenta colors even though
it mutes into brown.
More later.
Re: Looks like Ambrosia poplar to me.
Jamie Donaldson
Matt Prusik
>Ellis:
That log is exhibiting mineral stain. It's a known defect in poplar that takes logs and lumber out of NHLA FAS grade and moves them into a No. 1 Common grade.
By the way, that type of poplar is okay to use when the customer specifies "paint grade" for his final work. Modern primers and colored top coats will cover up the stain just fine.
No doubt it's pretty and would make a spectacular turned object providing you can keep the color. I think you're right on "tinkering" with the finish. And if you used some sort of clear varnish, lacquer or other type with UV protection and perhaps a drop of purple dye to tone the finish, you might get it to stay looking that way for a long time. Otherwise it will just go muddy brown.
Best of luck and thnaks for sharing.
Matt Prusik
