New Thompson tools
New Thompson tools
New Thompson tools
>I got my new gouges from Doug Thompson yesterday and made handles tonight. I'm off tomorrow so I'm going to give the bowl gouge a good workout on some of that cherry I got. I'm going to sharpen 3 gouges, the Thompson, a Sorby, Packard. I'll run each one until dull and then sharpen all 3 again. I shoud have a really good feeling for how long the edge lasts.
These are CPM 10 tools that have been hardened and cyrogenic treated. They should really hold an edge. My first impressions were great. They look good, he has put a good edge on but I reshaped them very slightly to fit my set up on my jigs and I use 100 grit wheels. They grind nice. Not too hard so removing the metal and reshaping was easy.
I'll let you know the results. I've got 3 days to turn as much stuff as I can so I'll have a good test of that gouge.
I love the shape of the spindle gouges which is why I wanted his. They are thick and should cut really cleanly. I probably won't have time to work with those much but I'll try to get at least one project in.
Re: New Thompson tools
Bob Moffett
Bob Moffett
>What is his website? I look forward to the results of your tests.
Molly Winton
>John I have some of Dave's tools too, but haven't had time to handle them. What are you using for your ferrels? These look wonderful.
Me too!!
Dave Peebles Lyons, Ohio!
>Hi John,
I got my 5/8" bowl gouge on Saturday. It looks great, now I just need some time to give them a spin. I have the whole day on Thursday to put steel to wood. I will also post my opinion.
Best wishes,
Dave
Thanks John
Doug Thompson near Cleveland
>I would like to see the results too. When a web site is done the BOSS (Ellis) will announce it. In a way this has been a WoodCentral project for the past 6 months, suggestions and knowledge from members of this site have helped along the way.
The first time they were shown was at the IndyFest. Mark Kauder took the time and effort to run the first non-bias test. The shanks are turned down because of a question I asked on this site. Even the detail gouge was made because Gorden Seto took his time and effort to design it (Seto detail gouge). Fog Tanner helped name the company. These are just a few out of many who helped in one way or another. Thanks everyone.
John, nice handles... well designed with the forthought of how it will be held when using it. Good job!
Jorge Castaneda
>Hi Molly,
I use short pieces of galvanized pipe with a hole drilled and tapped for a set screw. Very strong and cheap, works very well. I have Dougs gouges too and they work great. If you have something like a Kelton Handle that is another way to go.
Jorge
Dick Hines
Dick Hines
>It lloks like Duge is fixing to become a world renone tool maker.
I have 2 bowl gouges and a detail gouge. I love them all.
I use them in my Kelton handles
>Molly I forget what they are called. They go from screw thead to copper pipe. They come with a hex shank. I turn the wood down to a little bigger than the thread size. Then I screw it on. I back it off a little put some thin CA on the threads and screw it back on. They won't ever get loose like round ferrul's do. I just use a HSS spindle gouge to turn the brass round and true up any off center.
You can scrape or cut but you have to move the tool slowly. I like the cutting action because you can add beads, coves and details. Don't cut too deep or you cut into the threads. don't ask how I know that.
Re: Thanks John
>doug Had to try out the router on the handles. I haven't done that before. Looks nice but I guess I'llhave to wait a few days to let you know how they feel in the hands with the grooves. I may have to soften the edges a little.
Well I think I've piddled long enough so the neighbors are up and I won't drive them crazy with the chainsaw. I'm going to start with a natural edge bowl this morning and then I'll work on rough outs the rest of the day.
Carole Valentine
>John, I have the 3/8" and the 1/2" gouges and love both. I will be interested in your results. I think these gouges hold an edge a good deal longer than my other gouges but I have not done any sort of tests to confirm it. I use them in Kelton and Hosaluk handles.
tek-Brunswick, Ohio
>I have one of Doug's 1/2" U flute bowl gouges to test. He makes them in both U and V flute designs. I'm looking forward to testing it. I've been away from the lathe for 2 months due to a respitory infection. I'm almost fully recovered and should be able to get some lathe time in soon. I'll give an opinion on the gouge after I've had a chance to use it.
Mark Kauder, Phenix City, AL
>I do have 3 bowl and 2 spindle gouges of Doug's. I like them a lot. With Doug's permission, I showed them to my club members, and Doug says they are making him run overtime with their orders.
If you want a far above average gouge, at a below HHS gouge price, buy Doug's gouges.
I have mine in Kelton, Oneway, and Bosch handles.
Mark
Jes' let me know...
>...and we'll come up with some kind of announcement for sure.
Cheers,
Steven Antonucci
I think they're called compression fittings
steve antonucci
>I used them too, but I leave them with the hex look, since I finally got all of the little metal shavings out from under my hands. Use care if you turn copper or brass on the lathe, and never use your bare hands for clean-up.
Steve
John Clifford in Chicago (Go Bears!)
>I also have 2 of Doug's U shaped bowl gouges that I recently received. It's cold here in Chicago so I haven't have a chance to take them for a test drive yet (lathe's in the garage) but they look very well made. I have no doubt that I'll be buying more from him in the future.
John.
Fog Tanner
>I have been using one of The Thompson gouges for the past several weeks, a 5/8" "V" flute. I took it straight out of the package, yes they come in a plastic container and not wrapped in newspaper, put it in the Kelton handle that came with my McNaughton tool. It was the only tool that I have ever got that was sharp out of the box. I roughed out a 19" Pecan bowl and was into the next before I even thought of sharpening it. I have a Henry Taylor that I been using and was going to compare the two, but very quickly there became no comparison and I left the Henry Taylor for the light work. I will say that from past experience, I am not going to the grinder as often. I did sharpen The Thompson on my Tormek and got it too sharp , it would really take the wood off - a little too much, so I went back to a 100grit dry grinder. I think I just needed a larger/longer handle. But, I also wanted to see if I could sharpen it on my Tormek, got a razor sharp edge with a polished bevel - no scratch marks.
It comes with basicly an Ellsworth grind and is usable without doing anything to it. Our club has bought six for our Spring Retreat raffel and I had a chance to compare some of the various sized Thompsons agaisnt my Henry Taylor. The Thompson 1/2" gouge is about 1 1/2"-1 3/4" longer than the Henry Taylor when measuring the flutes. And the whole tool is hardened so you get that much more flute, but you also have some material for a short half round scraper when you grind the flute away. The 3/8" is also longer but I don't remember the length. The last 2" is gound to size (i.e. 1/2", 3/8", etc), as the rest is slightly oversize (around .015). And I love the gun metal blue finish, they really stand out amonst the other tools.
There is more metal under the flute than the Henry Taylor or a Jerry Glaser. This is true of both the "V" and the "U" shaped flutes. I also compared the Detail gouges and they are similar in shape to the P&N, but unlike the P&N (which are excellent tools) The Thompson comes sharpened.
After a small show and tell at the last club meeting, we place another order for some more Thompsons. Everyone that ordered a bowl gouge had to have a detail gouge also (one member ordered two). I now have a box of steel and after looking at the 5/8" "U" shaped gouge one of the members ordered, I am going to have to have one of those too. I had gotten the 1/2" "U" (along with a 3/8" detail), and after looking at these "U" shapes, these are not wimpy gouges like some of the others I have seen. There is some steel under the flute. The Thompson basicly takes the next step where Galser stopped. The radius at the bottom of the flute is larger, more steel under the flute, the finish is smooth and not peened so it slides easier, and LOTS more usable steel.
Right now, I am waiting for the spindle gouges that Doug is coming out with. I do a lot of spindle work and would like to have some 3/8" and 1/2" gouges that I didn't need to sharpen so much. But that also means several of each for the various bevel angels. I also have a prototype tool (non gouge) that I will pass on as soon as I can get a handle on it and try it out. But, I already know it will work great.
And you can't find a better or more trusting guy to do business with than Doug. He has brought us a great tool at a very fair price. As long as these tools last and the prices he is charging, I don't see him buying up an island in the South Pacific anytime soon. He took the Jerry Glaser gouge and made it better, and was kind enough to share it with the rest of us. I know I will be buying Thompson tools as long as he will keep making them. Now if the price of flat stock will just come down so he can make a skew.....................
Fog
Carlos Cabrera
>Where do you get these tools from ?? Is there a website ?
- Carlos
Fog Tanner
>You can e-mail Doug at dougswoodworking@aol.com. He has two sets of gouges, spindle and bowl and can give you the prices on each set. It cost more to make the bowl gouges so the prices are a little higher than the spindle gouges. The sizes are the US measurement (i.e. bar) and not the English (i.e flute).
He ships USPS and its $5.00 for one gouge. I sent an e-mail and two days later I was turning with a Thompson, and didn't have to drive across town. The cheapest way to ship is get a group order and spread the cost. Our last order was a total of 15 gouges and shipping was less than $10. I broke the charges down by the ounce and figured the cost per individual. It came to between .88 and 1.84, depending on what each one got. Still cheaper then the $5.00. Also saves time on Dougs end packing and shipping, ...so he can make us more tools...
Fog Tanner
>Molly,
I am currently using a Kelton handle which uses two set screws to hold the gouge in. I like being able to take the tool out of the handle for sharpening, is a lot easier than waving that Kelton handle around. It is made of steel and fairly heavy. This is the first "straight" style handle I have used very much, and I like it. Enough so that I am making some out of mesquite. Currently, I am sharing the Thompson with the McNaughton, which is a pain when coring and cleaning the bottom of the bowl. And I core each bowl, so I really need a new handle.
Normally I make the coke bottle type, but I am going to turn some cylinders and drill 5/8" holes in each end, one end about 2 1/2" - the other about 6". The deep hole will get some lead shot and a brass plug. The other end gets two 1/4x20 threaded inserts and a ferrel. Will also be doing the same for my 1/2" Thompson, same handle and lead shot, just smaller hole for the gouge. I am thinking about using the set screws on all my new handles now, and understand why I have seen a number of other people doing this.
>And don't forget parting tools and NR scrapers when you get the flat stock, Doug.
Mark
George Van
>Doug sent me the following photo a while back. The V shape bowl gouges on the left, U shape on right side. 5/8, 1/2, 3/8 diameters.
I am Overwhelmed
>I would like to thank each and everone for your comments and support. A few months ago this was still a hobby with one goal to make a high quality tool at a fair price. I am speechless...
I'm at work so this has to be brief.
Mark, tomorrow I will take a deep breath and order a sheet to make scrapers/skews, yes a skew made from this steel would be amazing.
The flutes are slightly shallow compared to other tools because;
1. It makes the blade stronger so it can extend over the tool rest farther.
2. You don't need a deep flute, almost all of the cuts are made with the front half of the cutting edge.
3. Notice they don't clog, I won't say they never will but you won't have a problem.
Get rich, if I figured each hour spent I'd quit and turn some wood.
I'm I having fun? YES I never have so much fun in my life. Everyday I get to meet new people, talk to them on the internet or telephone.
Oups gotta job,
THANK YOU AGAIN,
Doug
Re: I hate to throw a wet blanket.....
Jamie Donaldson
>... on the Thompson Tool name, but are you aware that there is/was another tool and lathe maker named Thompson about 15 yrs. ago? I have a long handled Thompson hollowing tool(about 5' when fully extended)and David Ellsworth had a Thompson lathe built into the concrete slab of his shop floor when I was there in 1990. Jim Thompson stopped making turning tools at some point and started a classic car restoration business in S.Carolina, so only a few old timers like me will remember the name, so I really don't think there will be much confusion with the name.
What's in a name
>Twenty five years from now some person will say the same thing about us... that's a scary thought.
Bill Blasic
Bill Blasic
>I don't think there will be any confusion between these tools or toolmaker once you've seen, held and used the Thompson tools.
