200+ woodworking book reviews
yacht sink in mahogany *LINK*
joaz
>So, I"m making a sink out of mahogany for a guys yacht.I know...but this is what he wants.
He is planning to epoxy it for the obvious reasons. My question to you guys it this....if I use filler on the wood will it effect the eboxy??
This is a very open grain wood and if it was for regular use, I would fill. TIA.
Joaz
http://www.maine-web.com/woodturning
Re: yacht sink in mahogany *LINK*
Jennifer@Indy.USA
>I don't know that answer to that...but my first thought is if it's going to be covered with the thick epoxy...why would you need to fill it? You won't be feeling the wood anyway? I'm probably missing something obvious, but thought I'd ask anyway.
Jennifer
nailshooter
>Joaz - I do some epoxy sealing with the West Systems 3 material. If you have a grainy or porous surface, it can be the devil to get the last of the tiny bubbles out of the grain. The bubbles reflect light like little diamonds after curing.
We pore fill, sand, then finish.
Robert
Russ Fairfield
>I have seen all manner of incompatibility between epoxy and fiberglass resins and wood fillers and glues. The resins not curing over the glue joints has been the greater problem.
I would select the epoxy product and manufacturer first, and then work backwards to the glue and any fillers that are used on the wood.
joaz
>Thanks all. My major concern is appearance, as the end grain is quite open and porous even after sanding. Maybe the epoxy will fill the end grain. Thanks again for all your thoughts.
