Resp-O-Rator
Dennis Bilevich
>Has anyone use this and your thoughts. Thanks Dennis
Resp-O-Rator
Dennis Bilevich
Re: Resp-O-Rator
>Dennis I looked at them hard when they first came out. They are very effective and apparently work very well. I just don't think I could get used to breathing through a snorkel all the time so I passed them up.
Same thought, bought something else
Ralph
>in this case, a Trend Airshield
Re: Same thought, bought something else ditto
John Kyler
>Got the Trend and have been very happy.
I just couldn't plug my nose and breath through a mouthpiece.
But price is a big factor?
Re: Resp-O-Rator
Bob Moffett
>Dennis,
I used to use a batery powered face mask and quit using it because it seemed like the batteries always ran down in the middle of a turning session and it was heavy. It was the 3M mask. I now use the Resp-o-rater and really like it. It is lightweight. I wear it under a full face shield and the filtration is much better than the 3M shield was. I only wear it when I am sanding, or turning cocobolo or cedar. I cannot turn cocobolo without it. I have been using the same filters for about 2 years which is probably to long, but you can clean them out with a shop vac. Hartville tool is running them on sale with a full face shield for abotu $45 which is a real deal. I think it is the best thing out there and I have tried several different things. They also have a little one that you can use for doing yard work, but yard dust doesn't bother me so I don't use that. I don't have any connection with the manufacturer or distributor or financial interest in them and all that stuff. I just really like mine and would not hesitate get another one if I lost it.
Re: Resp-O-Rator
James Duxbury
>I invented the Resp-O-Rator for exactly the reasons Bob is using it. I hate batteries and want the best in filtration. This has two large HEPA filters that hang behind your head--out of the dust. They cost about $8.00 per set to replace. Theirs say fine dust which means nothing, hang out in front in all the dust, and cost about $35.00 to replace.
This thing costs less than their 4 hour battery. I even mow the lawn with it now. It is great for those with allergies. A good Resp-O-Rator and ear plugs you can mow all day. It's almost fun.
If you don't like the nose clip just breathe through your mouth that is what I do. Works great.
Re: Resp-O-Rator
Dennis Bilevich, Prescott, AZ
>Thanks all for your help, think i will try one. Thanks Dennis
Re: Resp-O-Rator
Don in Northern Arizona
>Dennis,
I used one for flat work for a while. I tended to blow spit through the exhaust tube on my work as I leaned over it while sanding which I found annoying. Would be less of a problem working on a turning I would think. I gave up on it because the mouth piece was quite uncomfortable after extended use. YMMV. At the Conover turning workshop I attended it was the respirator of choice for both the instructors and students. I think the 3M 7500 half mask can't be beat myself.
Don
Re: Resp-O-Rator
Robert Henderson
>I have one. I haven't used it in a year or two.
The nose clip is uncomfortable and my lips tend to get chapped.
That having been said, it does what it is supposed to do at a low price.
Re: Resp-O-Rator
James Duxbury
>Don,
Saliva problems are because you are not using the Resp-O-Rator properly. The mouthpiece is a flat flange that is held between the lips---in front of the teeth. This allows your mouth to close, teeth together and swallow normally. You can't swallow properly or control saliva with your teeth parted. Take a drink and try it once.
Weather you use a Resp-O-Rator or not get something that works and has filters that tell both the filtering efficiency and micron size. Fine dust, main filter, final filter can be anything---and expensive too. And most of all don't turn your sander off and remove the respirator. That is in many cases the exact time of the highest dust consentration. Wear the respirator until the dust clears or you leave the area.
Hope this helps
