Almond anyone?
Almond anyone?
Almond anyone?
tm
>A friend who lives in Central California has pirated a section of dry
Almond in log form. Does this species lend itself to turning?
One of us will end up paying to ship it...
I'm wondering if its worth the cost.
Thanks,
tm
Re: Almond anyone?
Re: Almond anyone?
>The other species of Prunus turn quite well (Cherry, Apricot, etc.), so Almond would probably turn well also.
Re: Almond anyone?
Re: Almond anyone?
jim johnstun
>Almond turns well but has an exceptional amount of movement. I had some flat boards that were about 2in by 4in by 16 in. when they were dried, I planed them. They ended up 3/8 thick when they were flat. Turned a couple of small bowls and 1in. wall weren't enough for drying. These were 6 in. bowls. If it were me, I would pass on the deal as it moves to much for parctical work.
Re: Almond anyone?
Re: Almond anyone?
charlie b
>Some questions
Is the wood dry or green?
What do you want to do with it - large pieces or smaller ones - things with critical dimensions or not?
I've done some small stuff - 2 1/2 to 4" diameter turned lidded boxes ouf of dry - very dry - almond. The stuff I used has been very stabile - critical for a snug lid fit. It turned well and you can get a nice shiny burnished finish on it. The heart wood is a rich dark brown - not almost black brown like claro walnut - more like between milk chocolate and dark chocolate. There's enough contrast between the spring wood and the winter wood grain to make for a nice look.
So for small stuff, with relatively thin walls, it's pretty stabile - when turned DRY.
I'm a wood phreak so I'd try it - if it didn't cost an arm and a leg.
Re: Almond anyone?
Think hard before you buy.
Colin Spencer
>TM
Almond is plentiful where I live and turns well when wet. It checks like nothing you would believe, even sealed I loose over 50% of what I get if I don't rough turn it. It moves a lot. Dry it is very dusty and even with sharp tools shavings are hard to come by. Wet it rusts your tools and lathe as soon as a shaving lands and carpenter ants love it. Those are the negatives. The positives there is usually a beautiful contrast between the heart and sap wood. The sapwood is usually creamy in colour whilst the heart wood can vary from chocolate brown to a tan colour. The grain pattern is usually attractive.
I get mine for free so use it but if I had to pay a lot for it I wouldn't bother. I hope this helps.
Colin
Re: Almond anyone?
Re: Think hard before you buy.
tm
>Thanks for all input.
tm
