A Poor Man's Lathe Duplicator Rig
Ken Grunke from SW WI
By Ken Grunke
March, 2007
Inspired by Don Derry's adaption of Marco Berara's design, which Don posted in the WoW File Cabinet on Jan. 28, 2007.
After seeing that rig, my version was hastily cobbled together using spare parts from my scrap bins. Easily put together using salvaged/found parts, or purchased off the shelf.
Part A: The backbone of this rig is the toolholding base, which can be any fairly heavy sprocket wheel, gear, pulley, faceplate,or similar item, 4-6" diameter. I am using a cast iron gear with a 7/8" bore--a bore size of 3/4" to 1" will do just fine.
The base holds the toolpost (Part B), crossdrilled (C) to take the tool shaft (D). I added a setscrew collar (E) to the toolshaft to enable repeat accuracy of tool depth if it's necessary to remove tool shaft from toolpost.
"http://www.kengrunke.frih.net/duplicator/myversion/overview.jpg">
The rig slides around on a plywood platform, blocked up on the lathe bed to get the tool's tip in the ballpark of lathe center. Here it's just c-clamped to the lathe bed, but carriage bolts and wingnuts would be an improvement if you have access to the bottom area of the lathe bed.
Re: A Poor Man's Lathe Duplicator Rig
>I can't seem to post an image inline from another server location, so will try again by uploading one image per post in the usual way:
By Ken Grunke
March, 2007
do just fine.
>The toolpost has vertical adjustment of 1" to set the tool's cutting edge on center. This gives a range of 2" on the diameter--I can move the rig from a 10" mini-lathe to my Jet 1236 with only a small adjustment, and it can be fit on any size lathe with appropriately sized blocks under the platform.
The tool in use.
First of all, the tool's tip needs to be aligned over the follower pin (F) as close as possible, using either line of sight or an alignment gauge of some kind.
Then, the pattern (G) has to be situated into position underneath the spindle blank. There is some leeway here, at least front-to-back, as the tool itself can be moved in or out for fine adjustments.
usage
In theory, you should be able to approach the work from any angle, but only if the profile of the tool and the follower pin match each other. I didn't bother with this in the trial run, but if a round follower pin is used, the tool's tip should be round with the same radius. By the same token, if a pointed tool is used, the follower pin would be wedge-shaped.
The tool profile is a basic round-nosed skewchigouge shape and is a 1/4" round HSS bit epoxied into the end of a 1/2" mild steel shaft held in my setscrew handle.
>Pretty cool Ken. I don't use a copy attachment. If you notice the tearout on the outer portion of the beads and narrow areas, that is why. You have to take that into account and size your copy pattern accordingly. Then you go back and clean up these areas with a skew or gouge. I kept finding that I had to clean more and more areas to please me. Still it shows everyone a simple method for building a copy attachment and I'm sure several will give a try. Thanks for posting.
If I was doing 100 of something it might be worth it. I'm currently putting together a wayto do this with a router. I won't be able to remove all the wood or get the shapes. It's mostly as a very rapid bulk remover.
eaglesc
>Could you try to repost the pictures?
eaglesc
>PLease excuse the lack of coffee, I found it and it is ingeneous!
Thanks for sharing that!
Re: A Poor Man's Lathe Duplicator Rig *LINK*
>I had more to post last night, but fell asleep at the keyboard LOL!
This rig can also be used to cut spherical profiles! Here, I have the cast iron gear base pivoting around a screw driven into the base. I left the setscrew loose at the top of the toolpost, so the tool can be progressively advanced into the cut, and also rotated left or right.
Alternatively, the same follower pin used for regular duplication can be used as a pivot in a notch or hole cut in a template.
Below the picture, is a link to all my posts put together in one webpage to make it easier to read. Hope this proves useful to someone.
All Posts in One Page
more--Observations and improvements *LINK*
>I wasn't very impressed with the speed of using this setup, it's somewhat cumbersome. I couldn't help but think how much faster I could turn a shape freehand using a skew and gouge if I weren't restrained by a jig, and if I didn't need an exact profile. So I wouldn't call this technique a great time saver, although the roughing out may go quicker than with hand tools. That is how I view any duplicating rig, as a roughing setup--especially since, as with most other duplicators, it's hard to get a nice finished tool surface using this rig, so one should plan on doing a little finish work with hand tools.
Is it worth the trouble to construct?
Sure, why not--considering that it doesn't take any skilled machining, and uses off-the-shelf parts that can be put together in half a day's time if all goes well. I haven't had the opportunity to put it through it's paces on any multiple spindle turning job, but I have a feeling it can prove useful and it's cheap!
Improvements to make
This rig doesn't slide around very easily on the platform, so I would make the platform from laminated MDF such as countertop material, and glue a sheet of slick plastic to the bottom of the gear. A sturdier template is also necessary, this hardboard probably wouldn't last for more than a dozen copies at the most.
Again, here's the link to the webpage which has it all:
Everything in one webpage
