Buffing lacquer finish
stacey s
>How long should I allow a lacquer finish to cure before I buff it? I recently discovered how nice a sprayed lacquer finish looks after it has been buffed. I am using semi gloss lacquer. I buffed several bowls that had been finished for quite some time and then tried one that I lacquered yesterday. I discovered that the lacquer was stilll a little too soft to have buffed today. But the question is how long should I allow the finish to cure before buffing?
Stacey
Re: Buffing lacquer finish
jeff myroup
>Stacey,
I use deft lacquer all the time and buff with the Beal system. I normally wait at least a day. I also use very light coats. I finish on the lathe and rub it down with 0000 steel wool. I have not had a problem with it being to soft. I tend to do all my buffing at the same time. If you can wait for a few days or longer the better. With low humidity and warm temps, you should be good after 24 hours. I have also started to spray the lacquer and while still wet wipe it off. That way I have no globs or smears. I say this on the woodworking channel, Dick Sing was turning some stuff and just wet the wood with the lacquer and then wiped it off. After a few minutes he was at the buffer. Hope this helps.
Jeff
>Stacey I like to wait overnight at least but have buffed some things an hour after spraying. I buff much slower than most folks, about 1000 rpm with the 4" wheels so there is less chance burning through the lacquer. If I wait 24 hours I can buff at high speed with the 8" wheels. Still gotta be somewhat careful though.
stacey s
>Thanks for ya'lls input. I waited overnight but it seemed that my buffing messed with the lacquer. Might have something to do with the humidity.
Stacey
>Stacy Heat is the enemy of Lacquer. If you put too much Tripoli on the wheel and then push hard at high speed it will eat right through the lacquer, hard or not. Been there done that. Clean the wheel by running the sharp edge of a board across it. Then use a light touch and try again.
Mark Kauder, Phenix City, AL
>It really depends on what formulation of lacquer you are using, and what surface you are trying to achieve.
If your purpose is to give the piece an oil finish look, most any lacquer will work, and generally you can polish it within the hour. The volital solvents will (mostly) have evaporated.
Now if you are doing multiple coats, it starts to get more complicated. The thicker the coat, the softer the lacquer for longer (relatively) because it takes longer for the solvents from each layer to evaporate through the lacquer above. It also depends what solvents are being used. For instance, a greater percentage of Acetone, the faster the evaporation rate (that is why I use pure acetone for a thinner in cooler weather)
Some lacquers, like brushing lacquers (Deft) have a retarder formulated into them, so that they evaporate slow enough to let brush marks flow out. As a result, to take it much longer to dry completely. When I first began to doing lacquer, I used Deft. I learned that it would take a long time to become dry enough not to pick up dust. After 3 coats, it would take 3 days or so before I could sand it and have nice white dust come off it. Since I do glass like finishes, it would take many coats to build up the finish. It would take a week or so, and then I would sand it to a glass like finish and hand polish it. A couple of months later, the grain would show through again - because it was still out-gassing solvents and shrinking. Deft also has a low percentage of solids (the lacquer itself).
Higher quality lacquers will harden sooner (so you can sand and buff sooner), and have higher solid content (and will build faster). Better lacquers are not that much more expensive. Deft is about $25 a gallon, compared with about $35 a gallon for better lacquers.
Look at Behlan's Stringed Instrument Lacquer, Homestead Finishing's Magnashield, or McFaddens Guitar Polishing Lacquer.
John is absolutely right - buffing - heat is a bad thing. Keep the speed down, and keep the workpiece moving. I prefer wet sanding, and then hand polishing.
Mark
>Sorry, it is Hood Finishing - not Homestead Finishing.
http://www.hoodfinishing.com/Catalog%20Pages%20For%20WEB/Wood%20Finishes.pdf
Thanks Mark
Gary in Zirconia, NC
Carlos Cabrera
>Mark,
I see the magnashield and other lacquers come in gallon cans, how do you apply the lacquer? With a rag or brush? Or do you have to get all the spray equipment? Do you need to mix it with the catalyst before using it? Any help appreciated.
- Carlos
Thanks everyone
stacey s
>Thanks for all your input. John I hadn't thought about that but maybe I was applying too much pressure and it go to hot. I will try cleaning my wheel and keep a light touch. Mark thanks for the input on the finished. Yes mine is Deft from Home Depot. Several years ago I got a deal on gallon cans that I couldn't refuse($9 each) But it dries very quickly but doesn't seem to build up very much. I will have to try one of the other brands you suggested and see what difference that makes in the final finish.
Stacey
>Carlos,
Yes, you do need some spray equipment, though not as much as you think. If all you spray is bowls (and not huge bowls at that), you can get by with a little 2 gallon Walmart air compressor for about $70, and a $30 "HVLP" detail spray gun from Harbor Freight. Start there, and grow as your needs or desires grow. That is pretty much how I did it. Now I have a big 80 Gallon compressor, and quite a few spray guns, from the $30 HF gun to a $400 Apollo conversion gun.
Once upon a time, catalzed lacquer required mixing it with a catalizer, but today, most of them are "Pre-Catalized) and you just treat them pretty much like old fashion Nitro-Celulose Lacquers.
Mark
Keith Tompkins
keith tompkins
>the air-brush works great as well!!
