We value your privacy.
>This is the easiest way I've found to sand off the nubs after I've finished the bottom of a bowl.
This is a scrap piece Jam Chuck I use sometimes for the opening in vases. I added some Velcro Hook to the flattened end, and cut three circles from one of Vince's 3" discs, of each grit.
I like your sander, but what I do is just chuck one of my regualr sanding discs in a Jacobs chuck in the lathe or in the drill press. In the DP, you cna jsut lay the bowl on the tabel of the DP and bring the quil down lightly and sand the bottom. Of course, this assumes you have a DP. I also use it for sanding "of the lathe". I lower the table and block the quill "down" and sand away.
>I do that also. I also have a 1/4" handpiece for my Foredom flex shaft machine. I have sanding discs down to 1". Very handy for sanding the bottom of small things like boxes.
>Thanks, guys! Those are great ideas. I love the solutions that are really simple and in front of your face the whole time! I've been carving and handsanding the nubs off the bottoms of some of my bowls with less than stellar results :)
Great stuff!
Mike
Peeking at the forest through the trees in Apex, NC!
