Have a question? Ask Woody!
turning strawboard
turning strawboard
turning strawboard
woodenLeg
>1. Is it possible to turn strawboard? 2. Where would someone get the stuff? A really good friend to the town that I live in made his living by baling straw for mushroom growers and his family asked if I might be able to find and turn a vase out of straw. I hope that you can help. Thank you. Dave
Re: turning strawboard
eaglesc
>With enough CA you can make(and turn anything).
I would imagine you could evn turn flatulance.
robo hippy
>Environ Biocomposites out of Mankato MN makes a couple of different straw boards, but generally sell quantities (they also make Dakota burl/sunflower shell board). Some of the local hardwood places, not the BORGS, may carry it.
robo hippy
Don in Central Illinois
>Yes, but make sure you were a respirator when turning! Smells like wet cotton wood.
Bob Way, Canton, MI
>I used to do product development for a wood products company out of North Dakota, and some of our projects involved strawboard. At the time it was made by PrimeBoard. You could turn it. Very likely though it will have a finished texture very similar to particleboard. It is made pretty much the same way under heat and pressure so the surface is smooth, but once you penetrate the surface there is a coarser texture. The cell structure of the straw gives it good water resistance, but it will have a high silica content. Sand is a silica, so you may need to plan some extra sharpening for your tools.
Six years ago, most of it went to door/window and some millwork manufacturers for use in exterior doors and door jambs. There was a trial attempt to sell it at retail, but at that time it had not gained much acceptance. You may find it under a veneer wrapped door jamb depending upon the manufacturer. Or you might be able to contact PrimeBoard.
Bob Way
Canton, MI
Not straw, but maybe a substitute to get the look?
Craig Daymon
>Maybe turning something out of Palm? It has a fibrous, straw-like structure that might give the impression of bundled straw. You can probably find several examples of turned Palm by searching the archives. Lots of suppliers sell it in sizes useable as a vase.
-Craig
Re: turning strawboard *LINK*
Curtis Seebeck
>There is a fellow over at Penturners.org (Gary Max) who has sold a few pen blanks made with straw and resin. You might be able to do a segmented vase with some of his pen blanks. Just a thought.
Curtis O. Seebeck
"The Original Prickly Pear Cactus Pen"
www.TurnTex.com
Straw bale pen blanks
