Baldor bench grinder
Rick Pixley
>I'm in the market for a good 8in grinder..Abyone know of a good source? Thanks,Rick
Rick Pixley
Re: Baldor bench grinder
robo hippy
>I got my 8 inch baldor grinder through a local bearing supply place (Kaman). You can order then through Woodcraft, but it is more expensive. You can try Grainger, maybe look under grinding supplies in the phone book. It is expensive ($500 plus), but runs so smooth that you don't have to bolt or clamp it down. Also, you can apply a lot of pressure without in bogging down.
robo hippy
Bart Rhoads
>I purchased one of those no name brand 8" grinders from Woodcraft back in 2000 for $79 and have been using in on a regular basis ever since with no problem. I also know of a few other people with the same grinder with the same results.
Rick Pixley
>Thanks Bart,I too have the Woodcraft grinder and thought I had "no Problem" that is till I used a friend's Baldor this weekend..There is absolutely no comparison and now am suffering from envy and jealousy..Has anyone tried the grinder(or any tools) from Steel City,it looks good in the photo and is 3/4 hp with a substantial warranty?
Glenn Hodges, Nashville, GA
>I have been using Woodcraft's grinder for about 6 years with no problem. You will be able to buy a lot of other tools for the difference in the price. I will say I like my Steel City bandsaw.
Carole Valentine
>Well, that tells me to stay away from shops that have a Baldor grinder...as long as I don't know what I am missing I will be content with my Woodcraft no-name! I do have the Oneway balancing system on mine.
georgetroy
>Take a look at the Delta heavy duty 8" grinder. Mine runs very smooth without a bolt down. #23-725 weight 89 lbs. 1,725 rpm.
www.woodworker.com
Rick Pixley
>George,is this comparable to the top end models as far as smmothness and power? I see it looks almost identacle to the steel city model but substantially heavier..
E.T.
>I read that this Delta model had been discontinued. Mine runs beautifully, as good as my 7 inch Baldur, But other turners have written about their problems with the #725 grinder.
Steve Russell
>Hello,
I have two 8" Baldor Industrial grinders, a slow speed and a high speed. :-) Both cost about $850.00 - $900.00 each, but I have heard that you can get them for less. They run very smoothly and are very quiet. One thing to note with these large baldors, they take a 3/4" arbor hole in the grinding wheel.
Most of the woodturning catalogs do not offer a grinding wheel with a 3/4" arbor hole. Packard Woodworks is one that does, so check out the shaft size before you buy, so there are no surprises when you open the box. I recently got two 8" Blue SG Nortons ($99.00 each) from Packard to replace the old wheels and the grey beast is breathing again.
I also have a Jet 8" high speed grinder (about $159.00) that has served me well for many years and an el-cheapo 6" no-name that refuses to die. I think it cost about $39.00... I do not recall the distributor for the Baldors as I have had them for several years. These Baldors are brutally heavy, so weight may influence your purchaising decision when it comes time to figure the shipping. Good luck and best wishes to you.
Re: Baldor bench grinder-Rick
georgetroy
>I have no idea of the quality of Steel City grinders or any of their other equipment. My Delta works fine for me. I also have a Sears high speed 7" noisy grinder that is about 20 years. I wish it would die. GT
