Coolabah and Robust
Coolabah and Robust
Coolabah and Robust
Ed Moore
>I am almost ready to complete my comments on the Robust lathe that I purchased in September. I am still very pleased with the lathe and would recommend it to anyone who needs a large lathe.
Tonight I have a piece of coolabah (or coolibah) mounted on the Robust, which is serving as a clamp while the glue for a wasteblock is drying. The burlcap is 17" across. It was part of a group buy with the Capital Area Woodturners five or six years ago. I expect it to be dry and hard, but I hope it isn't like turning marble. Don Riggs, of CAW fame, gave me a 12" piece of red mallee burl he got then. It is pictured in its current state in the next post.
Ed
Re: Coolabah and Robust
Red Mallee burl
Ed Moore
>I am indebted to Don Riggs for giving me a red mallee burlcap. Having seen Jimmy Clewes' newest DVDs I had to give this a try. It's about 12" across. Someone who saw the piece tried to lift the small bowl off the "plate" and they were surprised to learn that it is one piece.
Ed
Re: Ed, both pieces of wood
Allen Neighbors
>are awesome... Love the piece you finished from the Malee burl. And I'd like to hear a report on how the Coolibah turned.
I've only seen a couple of shots of the Robust (as well as I can remember) but I thought it was black.
Yours looks like it's a shade of Olive... or some metallic green hue... is that right? Or is it my computer?
Either way, I'll be looking forward to your article about it when you get it written. :o)
Black, I overcompensated ...
Ed Moore
>when I adjusted, cropped, and resized the photo. Somehow it looks worse on WC than it did when I was working with it. Mea culpa.
I think the red mallee turned nicely - for a hard dry burl. The coolabah may be harder, but I hope it is turnable. I want to do something with it like I did with the red mallee, a cup/bowl on a plate. The wall thickness of the cup on the red mallee increases slightly as it gets nearer to the bottom. Today I plan to put it back on the lathe using the vacuum chuck and correct that. I just hope that this won't be one of those "last cut" situations we all dread. ;^D
Ed
Actually, the olive/green comes from ...
Ed Moore
>the doors of my shop and my heat pump. I looked at the original photo and there was a green hue to the walls. So, I adjusted the photo so that the wall is white and resized it without cropping or other adjustments. You still get some reflected green, but less. The lathe bed is gray, but it is possible that the plack pigment involved has some dark green in it.
I looked at the photos on the Robust site and two of the four pictures showing owners with their lathes have this same green/olive tone, so I think that it isn't just my lousy photography involved here.
Ed
Re: I'm relieved that Allen.....
Jamie Donaldson
>.. pointed out the color error first, relieving me of that duty. I believe Ed must also have some fluorescent lights on during the shot. The Robust gray looks nothing like Army OD-"olive drab," or "over dirt." ;-)))
Jamie, does the
Ed Moore
>flourescent lighting cause the green caste?
My brother-in-law is a very good photographer and does a lot of PhotoShop work for me. He took the last shot that I posted after making the walls white, adjusted it and sent it back. The burl had pink near the tailcenter and near the bottom edge.
QUESTION: Could this be the result of a monitor calibration problem that I have?
My PhotoSuite work seems to produce drab photos. Could this also be a result of that same monitor setting?
Ed
Re: Ed-the 2nd post is very close....
Jamie Donaldson
>. ....to neutral color, so if its off color or contrast on your monitor you need to do a color calibration. Do you have "Adobe Gamma" available on your "control panel" to run a calibration, and set the profiles for all photo images as "Adobe RGB 1998." Fluorescent lights do cause the OD color shift similar to the 1st post, and the mixed light sources in the 2nd image are responsible for the color shifts in certain areas of the image, such as the pink at the base of the burl, variation from neutral gray to OD along the bed ways, etc.
Re: Actually, the olive/green comes from ...
Jennifer@Indy.USA
>....where's your Brother In Law when you need him, eh?
