Munro mini, experiences?
Leppikallio
>Does any of you have that small version of the Munro hollower (with that 1/2" shank)? In pictures I have seen there seems to be only that small link between cutterhead and shank so the question is how high shoulders or wide flying saucers you are able to turn with that?
Or should I just forget that tool?
Re: Munro mini, experiences?
Ed Moore
>You may note that I asked about the Martel Hook Tool below, and I have ordered an MHT. A friend caught my post and knows that I have the small Munro and he asked about the Munro. You are right that there is just one link, not two, on the small version.
When the Munro arrived I was very surprised at how small the little cutter is. It takes real control to get a smooth cut with such a small edge being engaged with the wood. In fairness, I have not persisted and worked through the learning period with the Munro.
I was hoping to use the Munro to clear out the interior of small boxes, but I don't think it is efficient for that. It might be faster to use something else for a rough-out and use the Munro for smoothing.
At this point I see the Munro as a 5 on a scale of 10 and I was hoping for 8.5 to 9. But like I said, I haven't given it a fair chance yet.
Ed
Mike Nelson
>Leppikallio, I have the small cutter head and Rolly Munro recommended the 5/8 shaft. I wanted the 5/8 head but they say I have to buy it with the 5/8 shaft! Go figure. The cutter clogs regularly and the hood is difficult to adjust, the cutter tends to dig in, leaving a deep narrow cut. I would not buy this tool knowing what I know now.
Leppikallio
>I understand that 5/8" shaft is of course more rigid. Also good to hear that cutterheads fit to both shafts / all links... gives pretty much more options. Have you asked that bigger head directly from Rolly?
BTW, have you seen this excellent web page from Pascal Oudet, good description of (bigger) Munro hollower too.
Sorry, the link  *LINK*
Leppikallio
Pascal's web site
Mike Nelson
>Rolly has turned over sales to Binh Pho. They want to sell just the sets and not individual cutting heads. I wanted the larger head to see if it would remove more wood(you will spend a long time hollowing a vase with the small head) and cut smoother. Frankly a customer shouldn't have to play email tag to try to buy a product and I don't think the larger head would make that much difference anyway. I have ordered the Termite, will let you know how it works. That was a cool box on Pascal's site.
