Favorite hollowing tool for shoulder
Dawn Adams
>I am really starting to get involved in hollow forms. I am presently using the Donald Derry hollowing rig, but it does not allow for reaching around high shoulders. Any advice on a good tool to use - or a way to make a bar for the Derry system? Any help would be much appreciated.
Re: Favorite hollowing tool for shoulder
Carole Valentine
>Dawn, I use the Keltons. They work for me.
Re: Dawn, here's a suggestion... (long)
Allen Neighbors
>you asked about making a tool shaft for the Derry System... I'm presuming that is about the same as my Don Pencil Scorpion system. If so, here it is: (I don't know your ability level, so I'm explaining this as well as I know how. Hope you're not offended.)
Get a 3/8 bolt rod from a local hardware or lumberyard. (that's like a piece of "all thread" without the threads). Put the end in a vise, and bend a 90 degree bend in one end (about an inch long, which will be pretty easy to bend) Then clamp the bend to a block and use your drill press to drill a 3/16" hole into the center of the end that you bent (this is so you can insert a 1/8" cutter). If you drill all the way through the side of the "elbow" it won't hurt it, but don't go that far. Next, cut off the end that you just drilled, leaving about 1/2" of bend. That's all you need for your HF entry tool.
Next, lay the shaft down with the bend pointing to the left (as it would be going in the opening of the HF. In the top center, 1/4" from the end, drill a hole for a 1/4" set screw. (I think it's 13/64" bit) Thread it with a 1/4" tap. Insert a set screw. Score and break off a 1/8" cutter to about 1/2" long. Sharpen it... "fingernail".
Grind the sharp edges of the "bit end" to taper the end almost to the tool bit, then polish it smooth.
Cut the shaft off so it will be about 4 to 6 inches long, and shim it with copper tubing of successive sizes, so it will fit the arm-brace.
Make another one that the 90 degree bend is about an inch long, and another that is about 1-1/2". These will get you under the shoulder and to about 2" depth through a 1/2" opening. Take light cuts, about 1000 rpm.
This is what I use... before my laser rig is setup.
HTH,
Allen
Bill Crommett
>Allen : Post a pic, it would help to desdribe your process.
Dawn Adams
>Thanks Allen. This is actually very understandable even for me. I may give this a try this weekend. I'll let you know if it works.
Re: I offer an amendment to Allan's....
Jamie Donaldson
>... good project discription- I find a 3/16" tool bit to be less grabby than the 1/8" bit. And I use the idea I learned from D.Ellsworth for making a R angle tool for relieving steep shoulder undercuts- grind a cutting edge (shaped just like a hollowing bit) on an Allen wrench and mount in a handle- they're cheap, available in a world of sizes, and cheap.
Paul Porter
Don sells a hooked bar...
Paul Porter
>...for doing just that. Get a hold of him to find out the different options.
I also use the Keltons.
keith zimmerman, Normal, IL
Re: I'll try to do that, Bill.
Allen Neighbors
>I've just gotten on here to read and make a few posts. I've been trying to get my Trailerport ready for roofing, today, and had been out of town since last Wed morn (got back Sat Midnite), so I haven't turned anything for a week. I've been playing with my 7 month old Grandson since I got into the house this eve... wore him out :o)
Anyway, it may be a day or so before I get the pics posted. I've got to get that roof on before hail season gets here. I only began this thing two or three years ago, and noticed some deterioration in the rafters, so this warmer weather is what I've needed.
Re: You're right about the grabby part,
Allen Neighbors
>Jamie, the 1/8 bit is a bit catchier than the 3/16, but that's why I said light cuts. :o)
I do like my 3/16 cutters best of all, too.
Re: Here are some cutters for inside
Allen Neighbors
>the opening of hollow forms.
This first pic is one of a 3/8 shaft with 1/8" cutter. Crude as heck, but it works.
Re: Second pic is 1/2" shafts,
Allen Neighbors
>and one 5/8" shaft. Top is 5/8" shaft bent at 90 degrees. Middle is 1/2" shaft bent at 45 degrees. Bottom is 1/2" shaft bent at about 30 degrees. All these have 3/16" cutters.
The 3/8 shafts are easier to bend to your chosen angle, and the 1/8" cutters take smaller shavings, making them work very well just inside the opening, if you take light cuts.
Lynn Taylor
>Hi,
I am new to hollowing and would love a cheaper entry into it tool-wise. The tools suggested by Allen look like such a way. However, I don't know where to get th actual cutters.
Re: Lynn, I order mine from
Allen Neighbors
>Grizzly.com. Usually get them in 3-4 days.
Part No. G1507 TOOL-BIT HSS/COBALT 1/4"
Part No. G1506 TOOL-BIT HSS/COBALT 3/16"
I think they all cost $2.25 each now. I haven't ordered in a while, because I normally order 5 of each size at a time.
Grizzly has the 1/8" cutters also, but I get mine at a local store...because I only use them to cut underneath the openings of HFs, I use 1/8" key stock. They get dull really fast, but I take very light cuts at high speed, so I don't have to resharpen them much for such little usage.
