A55 Smoothing Plane
Woodburning your name, etc
Jim Rutten
>Hello All,
I had rushed through making a couple of bowls for my sister-in-law for Christmas and hadn't signed it. A week ago she brought them out and asked me to sign them. These were fully finished bowls. I tried woodburning my name, the year that they were made, and the type of wood in them. It left little ridges on the bottom of the bowl where I had done this. So, here's my questions, what is the proper sequence for using a woodburner to sign your name. My guess is sand, woodburn, seal, finish, but do you sand it again after you sign it? I feel like I have done just about every dumb thing out there to do. Here's one more. Thanks for all your help.
Re: Woodburning your name, etc
>I sand, burn, finish. I have had trouble burning through a finish unless it's very thin. May be a lack of skill thing for me since Idon't do a lot burning signatures. I do the same procedure with the Dremel Engraver but I can use it over a finish. I'll simply fill the signature with wax if I do it after the finish. It lookes better when done before finishing however.
What John said
Cyril Griesbach
Re: Turn down the tip temperature
Russ Fairfield
>It's all about temperature and technique.
The differences in wood hardness, and the little ridges and burned blobs, will tend to disappear with a cooler tip. For starting, use just enough temperature to barely darken the wood. The tip will also be moved slowly enough across the wood that you can compensate for any harder grain without making a burned bloom on the other side of it.
Learn to write by "gliding" the tip across the surface rather than pushing it into the wood. No friction or pressure is required to make a line. Think like writing with a fountain pen or a felt-tip, and not a pencil or ballpoint pen.
Connect all letters and figures so the signature and information can be burned without lifting the writing tip from the wood. The tip will get hotter every time you lift it from the wood, and make a b;oom every time you touch it back to the wood. Keeping it on the wood will keep the tip temperature constant.
Always start movement with the tip before touching the wood. In other words, never stop once the pen is moving.
It takes a lot of practice to get it right. Don't put the hot tip to the bottom of a bowl until you can gat it right every time on a piece of scrap.
When all else fails, do as John said. Get the Dremel engraver.
