Re: MDF glue block
David Walser
>For some reasons my edits to my post, above, did not take. Here's what it was supposed to look like:
It's interesting the varied experience we all seem to have, even when using similar materials. With regard to using MDF for glue blocks, Malcolm Tibbetts, in his book, The Art of Segmented Wood Turning, recommends using MDF for glue blocks. So, despite what some have said -- and I in no way doubt their experience -- MDF can be used successfully as a glue block for segmented turning.
The advantages of a MDF glue block is that the material is stable, uniform, and extremely flat. In the book, Malcolm has several photos showing several rings that have been stacked, one by one, onto an MDF glue block. Malcolm uses MDF glue blocks for flattening rings as follows: first, on the disk sander, sand one side of the ring flat. Attach the ring with hot glue (yes, hot glue) to the MDF glue block (sanded side towards the glue block) and turn the ring true. Using hot glue requires taking very light cuts -- which might explain why Malcolm did not warn about MDF coming apart as others on this list have experienced. Hot glue allows the ring(s) to be taken off of the glue block very easily. (Having to part the ring off or pry it off risks breaking the ring.) Hot glue also allows the glue block to be used several times.
In addition to hot glue, the book shows MDF glue blocks being used with double sided tape and yellow glue.
