First Segmented Bowls
Bob Fawcett
>Here is an Oak Bowl I turned today. It is sanded to 400, but has no finish yet. This is my second try at a segmented piece. I'll post the first below. This has 6 rings of 12 segments each and a solid base. When I cut it off, I almost didn't leave myself enough wood at the bottom, so I couldn't do much with the foot.
So far I have only made a sled for 12 segments so everything is 12 for now.
Re: First Segmented Bowls
Bob Fawcett
>This one is actually the first. Its Walnut and has 2 coats of Watco on it. I plan to buff it later.
This is my first attempt at a segmented bowl.
Critiques welcome.
John Bussom
>Bob,
Both of your bowls look great, really like the 2nd 1st one!
I could show you what they look like without a base, I have 2 or 3 hanging in front of my lathe as a reminder, I finally stopped doing them with the thin walls. I usually do 18 piece segments and it gets sickening when it happens.
John
Bob Fawcett
>John,
Have you ever mixed 18 with 12?
Does it work out OK. I thought about making the upper rings more segments to get the lenght down a little, but it seems like an 18 would want to line up some joints with the 12.
John Bussom
>Bill no not on the same ring because the miter angle would need to be different, 15 deg for 12 segments and 10 deg for 18 segments!
You could use 12 on one ring and 18 on another.
Something else you can do though is add a verticle spacer between segments, but your segment length needs to be shorter by whatever thickness you add whether it be 1/16" veneer or 1/2" piece of something!
I don't know how you came up with your design but I use the software from http://woodturnerpro.com/, no affiliation just a happy user, can't say that it is everything but it helps me. Also have 3D but that one I seldom use, now I'm ready for the lamination program as soon as I don't freeze in the shop!
John
Bob Fawcett
>Sorry I meant stack an 18 on a 12.
I had no real design. I just cut 12 equal lenght pieces and made a ring. I made a few rings and stacked them up. I adjusted the length of the pieces until I had ring sizes I liked. The rings were made from strips cut off 8/4 stock, so they were usually too wide. I wasted more wood than I really needed to.
Bob, I haven't done any segmented bowls
Don Henthorn
>but those look pretty good for your first attempts. Looks like you got the hang of it right away. From what I can see in the picture the joints are darn good.
John Bussom
>I forgot to mention that there is a free trial download at that link I sent, good for 30 days if I remember right. And you won't waste more wood.
One thing I thought of is if you were to go from 12 to 18 on the next layer it will throw your corner alignment off, don't know if that makes sense but when I line up my seg rings I line up the corners best I can.
John
Allen Neighbors
>Well done, Bob. Both of them. I love to see these segmented pieces... and 12 or 2,000,000,000 pieces would make no difference to me... I couldn't do either. I've never done any... I envy your patience... and that of the other segmenters. :o)
Thanks for posting them.
Jimiles-Charlotte, NC
>Bob:
You are on the right track. You learn to do segmented work by cutting and gluing rings not so much by the turning. Try a few pieces by the "seat of the pants method" and then when you are ready to go study the charts and use the math to calculate a plan it will make a lot more sense. I do 98% of my segmented work at 12 pieces. As mentioned, once you have 12 piece with angles cut you can put most anything you want in between then to make a larger ring. You can also cut your 12s in half and have 24.
MountainMan
>Hey Bob
Do you happen to have any pictures you could post here - on the building of a ring - then the addition of more rings prior to actually turning??
One look is worth 10,000 words - fr me, anyway!!
Regards and nice work!!
The MountianMan
