A55 Smoothing Plane
clear as mud
clear as mud
clear as mud
Bill Stehman
>Thanks for all the comments and emails, so here is a quick how to for the overly curious that can't wait... chuckle.
To make a simple 2nd generation zig zag blank. Select various shades of wood, I like 6 or more.
The more subtle color changes the better the illusion. Stark colors will look like a checker board.
Plan ahead and cut more than enough strips for the size bowl you want. I have tried 3/4, 1/2 1/4
5/16 but like 3/8 best. Glue this first lamination together choosing your color scheme. Now cut this blank into the same size strips at your choice of miter. I have tried 22.5, 30 but 45 works best to my eyes. Lay out and line up on a glue surface. Flip every other one. This gives you the basic zig zag pattern all segmenters learn first. I then glue up two half's separately , an 8" bowl would be two 4" pieces. When these are ready I dry clamp together and draw my circle rings. The more rings the better the pattern. Doug Newlove wrote a nice article covering cutting ring bowls in last month's Woodturning Design.
I use a simple circle cutting jig for the BS to cut narrow half rings, then glue these together. Flatten and align the patterns one at time. Presto.... you have a mostly completed bowl to turn.
The curving pattern is achieved by the slope of the bowl. It's that simple.
I always make multiple bowls changing each a little. Have fun and I will do a step by step on my next series with some pics for those who have no experience or couldn't follow this.
Re: clear as mud
Re: clear as mud
John Bussom
>Well Bill as you say it's "clear as mud" I understand the 2nd generation zig zag aspect but not the part of "all segmenters learn 1st" so I guess I will be looking forward to the step x step process!
You lost me somewhere between the 1st sentence and the last :)
John
Re: clear as mud
Re: clear as mud
Ron in Drums PA
>Do you have a picture of just one or two rings?
Parquetry quickly comes to mind. Same technique?
Re: clear as mud
Re: clear as mud
Cyril Griesbach
>Bill, does your technique follow (somewhat) a "bowl from a board" technique?
Cyril
Re: clear as mud
Re: clear as mud
Bill Stehman
>Ron, I don't but will glue some up when I get back in a week or so. Parquetry is basically the same then cut a ring bowl. 2nd generation lamination is just easier for me.
Yes Cryil, bowl from a board is just another name for the age old ring bowls. They have been made since shortly after the band saw came out. My father started making them in the 40's. I still have some of his Home Craft magazines dated in the late 30's showing how to make ring bowls. They have been mass produced in the Pacific Rim since after the war for rice and salad bowls and are still today. Look in the wooden bowl section of a KMart or Target, most are ring bowls because the are the most efficient use of wood.
