Pink Mozart and Bloodwood
Bob Way, Canton, MI
>A short time ago there was discussion of turning alabaster. I just finished up this piece. It is pink mozart alabaster with a bloodwood rim and foot, although it's hard to see the foot. It is 5 3/4" wide and 3 1/4" high. There are two pictures each showing an opposite side. As always, I'm looking to improve my eye and skills with your help.
Re: Pink Mozart and Bloodwood
Re: Pink Mozart and Bloodwood #2
Bob Way, Canton, MI
>This view shows a sand inclusion that can happen in the alabaster. It didn't show up much until I had turned the outside shape.
>You're looking to "improve my eye and skills with your help"??? You've got to be kidding.. That's a gorgeous piece!
Bill Luinetti
>Beautiful...what else is there to say?
eaglesc
>Definately COOL!
Bill Stehman
>Beautiful Bob, what glue did you use?
For a minute there....
Dave Belser
>I thought you were going to introduce us to some new wood called Pink Mozart!
The bowl looks very nice. I saw an alabaster turning demonstration at totally turning in Albany this fall - I'd like to try it but just don't know about all the dust!
how do you attache the wood so that it won't crack when it trys to shrink around the stone?
- Dave
Re: For a minute there....
Bob Way, Canton, MI
>Dave, the dust can be a problem for sure. Most of it is heavy and falls, but then there's always that fine airborne stuff. I made a dust hood that catches a lot of the sanding dust, and I have an air cleaner that will get some more. I'm still looking for that ultimate solution to the problem though.
The rim and foot are segmented, and are turned fairly thin. Maybe an 1/8" thick or so. I do start with a thicker assembly and turn a tenon on it to fit the opening in the alabaster. Glue it into place and then turn it down. So far, I've not had any problems with movement.
Bob Way
Bob Way, Canton, MI
>Thank you, Bill. I used Weldbond on this piece for both the segmented rim and foot, and to mount them to the stone. I had been using epoxy for awhile, but the seams seemed a little thick to me. I'm still doing a little durability testing with the Weldbond, but so far so good.
By the way, I meant to tell you your laminated ring bowl was absolutely outstanding.
Bob Way
