Martel Hook Tool - MHT
Ed Moore
>I have ordered the small MHT and wonder if it is a good way to hollow boxes. I would very much appreciate comments from those who use or have used the MHT. Also, suggestions that may shorten the learning curve for me are most welcome.
Thanks,
Ed
Re: Martel Hook Tool - MHT
Bill Crommett
>The Martel hook tool works great in green woood, but I broke my first one by being too aggressive in dry Maple. But Martel replaced it for half price.
Mike Nelson
>Ed, I see you aren't comfortable with the Munro hollower, same here, it clogs constantly and is hard to adjust the hood. Finally took the hood off and use the tool for rough hollowing, also they want me to order another 5/8 shaft to get the 5/8 cutter head! I researched the Termite and will be ordering one, anybody else use it?
Ed Moore
>Bill,
My purpose in getting the MHT is for boxes, and of course for boxes the wood should be dry. I guess that I should remember not to be too aggressive. Thanks.
Ed
Ed Moore
>Mike,
I haven't given the Munro a fair chance. I need to take some scrap wood and get beyond my discomfort level. But you are right, adjusting the Munro can be a challenge.
Ed
>Ed I have a ring tool and have made my own hook tool. I don't like them for boxes. It's just too handy to use my bowl gouge that I have sharpened to a steeper angle, maybe 50 degrees. I have also used my spindle gouge a lot. I felt like the cut was slower, probably because the tools aren't very beefy so I didn't take big cuts.
I need to turn a box or two today and one of things I wanted to learn is the cutting techique that Raffen uses where he cuts toward 12 oclock with the flute facing toward 2 oclock. It looks like a bevel rubbing technique. I use the flute toward 9 with the top wing really close to the wood. I'm not sure how those two cuts differ but I'm going to find out today.
I've seen a ball end, end mill used to hollow boxes and it really peels out the shavings. I'm not sure how you sharpen them when they get dull.
Ed Moore
>John,
I suspect that I will reach the same conclusion that you have reached in regards to the ring and hook tools. I have ordered the small (1/4") MHT and wondered if I should not have gotten the medium sized tool. I am getting the impression that the MHT's are great on green wood, but may be less satisfactory on dry wood, such as when turning boxes.
I have the Raffan DVD "Turning Boxes" and I decided that his tools cut sharper than mine - at least the skew does ( ;^D ). And he is obviously a master at the use of the skew and gouge. My background makes me pause and try to figure why a back-cut overhead works and they don't use that cut on the downside. I'm not there yet. Good luck with your "Raffan box session".
Ed
Peter Hyde
>Mike, I have a Termite with all 3 sizes of cutters. It takes some learnig and would probably be better with a 5/8" or 3/4" shaft. Why not make the shaft yourself and order the cutters from Oneway. I use it mostly to do goblets and HF from green wood but have used it on dry and semi-dry wood as well. It does appear to clog at times but strangely it keeps cutting. I find it is my first choice now for hollowing. Mine is now 5 years old and I have broken 1 cutter from a bad catch during a very aggressive altercation with some dry Honey Locust.
Re: termite
Mike Nelson
>Thanks Peter, that's what I had planed, the 1/2 and even the 5/8 shaft are just too small to go deep. I watched a video on the Termite and it is presented at a different angle than the others. I'm told it leaves a smoother finish, we'll see.
have both tools,use the termite
robert davis
Brad Vietje
Brad Vietje
>Hi Ed,
I have the Martel and love it, especially for green wood. For boxes you are limited by the angle of the tool relative to the shaft -- you can easily work the upper areas, or wide shapes, but you are restricted as you go deeper. A simpler hook tool, like the ones by Mitch Wolok, will probably do a better job on boxes. I have that one, too, which I bought from Mitch at the Providence AAW. I think Michael Hosaluk also sells them -- if you look around on the web, you should find contact info.
The termite should also work well, but I've only used one to hollow out a vase in green wood. You can use it with the loop almost vertical, just giving it a little CW rotation and pulling the handle toward you to pick up a cut. Don't use it on dry wood with the loop (cutting edge) parallel to the floor, or you'll have an exciting time.
Safe spinning,
Brad Vietje
Newbury, VT
