Platter started
Platter started
Platter started
Mikefrom Tn.
>21" Cherry glue up. Got this far today. It was a little off kilter when I turned her around. Have to work on that. I need to come off the cash and buy the outrigger. Would have been alot easier. Could someone post a pic of a standard base, I guessed on this one. Any special formula on how wide the dia.? 20%, 30% of the width? Looks like I should have gone anoyher in. or two.I believe I'll go with Tung oil. My standard. Anyone go any higher than 400gt. on cherry? The bottom cleaned up real good. Ill post again when I get finished.
Re: Platter started
Steven Antonucci
poorman's outboard assembly
Steve Antonucci
>I built this to handle larger diameter bowls and platters.
In short, it's blackpipe with a T-connector. Blackpipe is marginally too large for the banjo, but can be turned down with the larthe on a slow speed and a file and or sandpaper. I plugged the ends with a turned wooden scrap because it filled it with sand to dampen vibration.
The end support is just some scraps with a hole in it to slide the other end of the bar. I think it cost me about $15 in new parts, and about an hour.
Steve
