Chatter tool- really cheap
Garrett in Victoria BC
>Sometime before 07 Jan, someone posted a useful description of making a chatter tool under the subject on this post. Although I copied the text, I somehow lost the author, and cannot find the post again. Can someone help so I can give credit where credit is due?
TIA, Garrett
(Editor WC Articles & Reviews)
Re: Chatter tool- really cheap
Fluting Jigs for the lathe
>Here's another. Author, please?
Thanks, but
>this is a different article, and I'm looking for the author's name so we can credit him/her when we publish it.
In case this jogs a memory, here is the original post with some editing but no photos, and of course, no poster's name:
Everyone wants to try out a chatter tool and once you get one you�ll know why and wonder how you got along without it. However, because they are somewhat expensive you always want to know if you�ll really use it, and if it�s worth the money. Ideally you have a friend who has one and will let you try it. If you don�t then I have a solution to let you try one without any investment.
I use a hacksaw blade from a sawsall. You can find these at construction sites where they are using steel 2x4�s. They throw them away by the ton�s so they are usually laying all over the place.
I break them so they are about 3 inches long and then grind off the teeth. I reduce the front end to about 3/8�, and then put a V shaped nose on it. If you want a stiffer spring for deeper chatter cuts leave it the full width or clamp another part of a blade underneath to add thickness. More on that later.
To use the tool simply clamp it in a pair if vise grips. Extend the tip out about an inch. More extension makes the tool vibrate slower. Less extension makes it vibrate faster. The faster it vibrates the closer the chatter work marks are together.
This is the chatter tool in use. Move the tool rest back about 2�. You want the vise grips on the tool rest. You may need to lower the rest, too. For your first experiments, position the tool so it cuts about 7 to 8 o�clock and tilted down like using a scraper. You can tilt the tool to the left, to the right, or straight up. There are a lot of variables to chatter work so you must be willing to experiment.
Here�s what affects the look of the chatter marks. The distance the blade extends beyond the support, how far the tool rest is from the piece, the flexibility of the blade, the rotational speed of the work, the shape of the tip of the blade, and the distance you are cutting from the center. If you vary any one of these it changes the look of the chatter work.
A chatter tool only works on end grain.
A good way to learn is to turn a cylinder about 3 inches long and 1� to 2� in diameter. Insert this in your chuck and clean up the end with a spindle gouge. Now try the chatter tool. You should hear a loud shrieking noise. If you don�t, push harder, rotate the tool left or right and up or down. This should get you started. Clean up the end of the piece with your spindle gouge and do it again. If you are successful and get some chatter work you like, cut the end off with a parting tool and save it. I leave a small tenon on the back of the button to make it easier to glue into a project.
This is an example of the chatter work this tool will do on maple end grain. Below is a sample of some of the chatter work I�ve done on Corian, Tagua Nut, and cocobolo. If you look at the cocobolo piece you will see that the chatter work angles in two different directions. This is what happens when you tilt the tool left for one cut and then right for another. I cleaned up the joint where they meet with my spindle gouge as well as the outer edges.
You can apply color to the chatter work by using a felt tipped marker. This colors the top surface. You can also fill the recessed parts of the chatter work with colored wax and then wipe off the excess to leave the outer surfaces bare.
I know one is mine.
>Garret The chatter tool article is mine. I still have the whole thing with photos if you need it.
It's highly possible the Fluting article is also since I've been teaching that a lot lately. Without seeing the article I can't say for sure. John
Re: Here's another one for you, have fun and take
>Excellent job Leo. I wonder how it would have worked if you put another piece of split wood over the chatter tool blade and drilled and tapped that and then harden the threads with CA glue.
I've also made litte "T" nuts by putting the nut on a short piece of threaded rod and then chucking this thing up in my hand drill so the nut is up against the jaws. Then rotate the nut on the drill and use the grinder to round off about half of it. Then you epoxy the nut in a hole similar to your techique of hammering the nut in place.
Leo Van Der Loo
Re: Here's another one for you, have fun and take *LINK*
Leo Van Der Loo
>Hi John.
The chatter tool article is by Andrew Hilton, not mine.
I brought this one to the fore, for those that are interested in the chatter tool use and making.
Ken Grunke also has a write-up on the making and using of a shatter tool, also like yours easy and simple to make. Link added.
As for the T-nut, I would have used a heavier pipe, or weld/braze a nut on to the pipe, another way, if one has no welding equipment, would be to turn part of the outside of the nut down to get a shoulder, than install into a fitting hole from the inside of the pipe and then epoxy/solder in place.
Have fun and take care
Leo Van Der Loo
http://www.crwoodturner.com/chatterwork/
