Finish for box elder?
Scott Hurley in N. VA
>I'm sure this question has been asked before, but what's a good finish for box elder to keep the nice light color? I usually use an oil-based finish (e.g. Watco), but I'm afraid that might darken the box elder. I was thinking of water-based poly, but I'm not sure. Suggestions? Thanks.
Scott
Re: Finish for box elder?
Gary Evans Tallassee, TN
>To me, water-based poly gives a bluish tint to light colored wood. I like lacquer for a clear finish on box elder.
Gary
Jim Swank
>I commonly use Behlens salad bowl finish. It's not water clear, but ambers only slightly, much less than Watco danish oil.
Mac
>Lacquer works the best for me....
Ryan Dicker in Renfrew, Ontario
>Sometimes I use Walnut oil for Box Elder if I want to keep the colour. It goes on relatively clear and will still provide a little enhancement of the figure without the discolouration. From my experiences though, I find that it is not as durable as a standard oil finish (Linseed oil for example) so many coats are in order. It's food contact safe and water/alcohol proof. One of my favourite finishes to use on any wood.
Ryan
Bob Rogne
>Scott
I turn a lot of box elder burl and non burl and find that lacquer is the best for keeping close to natural color. (Both light wood and red-black or blue colors in the wood).
Just my thoughts.
Bob R
West Mac Turning in Mesa
Thanks and a follow-up questions
>Thanks to all who have responded. Question for the 3 of you who suggested lacquer - do you spray, brush, or wipe it on? Do you thin the first coat? Thanks.
Scott
Re: Thanks and a follow-up questions
Mac
>Hi Scott, As I dont use lacquer a lot,I use the spray cans that I buy at the lumber yard.Probably not the best grade,but it works well for me.Does take several light coats to get a good build.The last couple coats I use the matte or satin type as I dont care for a shiny finish on most things.If you have some extra box elder,try bleaching some of it. It looks very similar to holly when bleached.
