Veritas - Innovation in Tools
Wood burning pen source?
Dominic Greco in Richboro PA
>Hi everyone,
For give me if I have asked this question before. I saved much of my woodworking info on my old hard drive and it isn't until I look for it that I realize that it's gone.
I'm looking for sources for wood burning pens. Most notably with the 10A type tip as sold by Woodcarver's Supply. Now I know that Woodcarver's Supply sells these pens. That's not the problem. What I've found is that their standard pens (Like the one supplied with my Burnmaster Hawk) get very hot, and are uncomfortable to hold for long periods of time.
When I asked this very question a couple years ago, I seem to remember someone (it may have been Art Liestman and Molly Winton) recommending the Detail master pens. But I'm not sure if I have the right one here. I'm looking for a pen that won't roast the tips of my fingers while I'm using it! :>)
Anybody have any recommendations?
Thanks,
Dominic
Re: Wood burning pen source?
Steven Antonucci
C'mon Dom! A simple engineering exercise!
Steve Antonucci
>What's the problem?
Fingers get hot from holding the pen?
What can we do to fix it?
Use your toes instead? Nope, that just shifts the problem.
Build up your tolerance for pain? Nope, that just masks the problem.
Hmmmm... (I smell the wood burning -I hope it's not actually fingers :-)
Why do oven mitts work? Thermos? because they insulate us from the environment by being poor conductors of heat. What you need is something to insulate your finger from the hot thingy...
My work here is done. ;-)
Steve
AndiWolfe
>The air-vented style doesn't get quite as hot as the original design. You can reduce the heat transfer to your fingers by covering the pen in some neoprene material or a plastic mesh. Woodcraft sells some neoprene covers - 4 for $10. Alternatively, go to the hardware store and find some tubing that will fit your pen.
Re: C'mon Dom! A simple engineering exercise!
Tommy Holmes
>How about thin cork wrapped around the pen?
Wally Dickerman in Arizona
>Dom, I use Detail Master pens. I use an old used golf glove. Fits quite tight so I don't lose any feel for the pen.
Wally
Don in Central Illinois
>Possibly try the new Ovglove. Sold at discounters like WalMart, Cosco, etc. I can pick up things right out of the oven and the fit fairly snugly, so you will still be able to 'feel' the pen.
John Kyler
>I was thinking that was a good idea too.
Maybe some of the material can be cut and wrapped around the pen..
John
Molly Winton
>The pens that Woodcarver Supply sell are the DetailMaster pens. They've redesigned them making them thicker than the old style so their rubber sleeves no longer fit them. I've done a couple different things to insulate them. I turned a wood sleeve for one, but found that even very thin the pen felt too bulky. I'm using a rubberized bandage material right now. It's the first-aid stuff that's stretchy and sticks to itself. I wrap it around the pen a couple times, and it seems to work. Eventually I replace it, because the heat of the pen gets it slightly sticky, but it's not too bad.
Optima *LINK*
Jennifer@Indy.USA
>Dom,
I use the Optima burner and pens. They come with one foam wrap at the tip end, but for $1.00 more he'll put two more on to cover the length of the pen. I really like this unit and the pens. They don't get hot much at all.
Jen
Optima Pens
They look comfy!
>Jennifer,
Thanks for the link. I added it to my bookmarks.
I wonder if they fit on a Burnmaster Hawk?
See ya around,
Dominic
Thanks Molly
>Molly,
Thanks for the input. Turning a wooden sleeve might not be a bad idea for me. And using the bandage wrap is a good one as well. Although I've tried tennis racket wrap and it got too sticky (but that stuff is SUPPOSED to be sticky, right?).
I'm thinking that I'm going to try Andi's neoprene tubing idea. If I'm not happy with that, Wally's suggestion on using the golf glove is the next step.
Thanks,
Dominic
Nevermind!
>Jennifer,
Maybe I should have read the Optima site better! I just looked and found a link to the Pen FAQ. And there is my question answered right there. Looks like they are compatible.
See ya around,
Dominic
Re: Nevermind!
Bill Hale / Woodspinner
>YOU KNOW IT SOUNDS LIKE MAKING RUBBER GLOVES FOR LEAKY FOUNTAIN PENS TO ME.
Dont't buy the bad stuff and the dealers will have to make the improvments to continus to sell.
Good turning and be safe
Bill in Casa Grande, AZ.
Ordered some Optima pens
>Hi Everyone,
Today I called PJL Enterprises (makers of the Optima pen and wood burner) and spoke with the owner, Pat. He's a real nice guy who is very knowledgeable about his products and the state of the art. After we talked for a while, he helped me out with my selection. I ended up buying a Medium Skew (#11), a Small ball tip (#19S), and a #17 (also called a Coarse Hair Tip)
I'm not saying that the Detail Master Pens are not great tools. After some careful consideration, I choose the Optima. I choose these pens over the Detail Masters for a couple reasons.
One, they were recommended to me by my friend Jennifer Shirley, and by numerous other woodturners. Two, the Optima pen body is Phenolic, with a composite core. The Detail Master's body is aluminum. Which do you think radiates more heat when in use? If you said the aluminum, you're right. So it's no wonder the standard detail master pen gets almost too hot to hold after a while.
At first I was only going to buy the #11 and 19s, but Pat was asking what I wanted to do with it. I told him that I wanted to burn some straight lines and make a type of checkerboard on a bowl (ala David Nittmann). He recommended the #17 since it's shape allows it to burn a line and "follow" it, rather than be lead astray by the grain.
I'd like to thank all of you who provided input. It was with your help that I was able to come to such a quick decision.
Thanks,
Dominic
