soap solution
soap solution
Steve Kubien
soap solution
Steve Kubien
>I have read about alcohol soaks for drying roughed green blanks, paper bags, vented shelves etc. Can someone explain dunking in soap? I assume this is also to aid a speedy dry time for roughed blanks but I'm not sure. What are you trying to accomplish with this and how do you go about it?
Thanks everybody,
Steve Kubien
Ajax, Ontario
Re: soap solution
Re: soap solution
Rick Davenport
>Check out Ron Kent's website.
I believe it ronkent.com
He goes into some detail on the process.
R
Re: soap solution
Someone from Ajax doesn't know about soap?;)
dwr
Re: soap solution
Re: soap solution
robo hippy
>I have used both soaks a lot, but now use the LDD. I prefer it. You take the cheap brown liquid hand dishwashing detegent and mix it with equal parts of water. Bowls soak for 24 hours, or more if you feel like it. Some just drip off the soap when they are removed from the mix, I take mine and rinse them off (outside with the hose in the summer, and in the kitchen sink in the winter. Dry as you normally do, on a shelf, in a bag, in the shavings, etc. When dry, sand and finish, or return to final thickness.
With the experimenting that I have done, I can see and have measured no difference in the drying time, movement, or cracking of bowl blanks done these ways (which includes air drying). The only difference that I have noticed is that the LDD soaked ones sand out a LOT easier. I do turn to final thickness, usually 1/4 to 1/2 inch, let them dry and warp, then sand and finish. If you soak, and then return, I don't think you will notice any difference. DNA bowls seem to be harder to sand out than air or LDD soaked ones.
robo hippy
Re: soap solution
Steve Kubien
Thanks for the link.
Steve Kubien
>Yup, Ron Kent's site seems to have what I am looking for...and more! There is some truly amazing work to feast upon.
Cheers,
Steve Kubien
Re: soap solution
Steve Kubien
LOL, There's your daily 'freebie'
Steve Kubien
Re: soap solution
Steve Kubien
questions arise...
Steve Kubien
>So you use this as a means to save blanks for checking, not speed up the drying time? Ok, I can live with that. I thought this soaking was done to speed things up but have obviously been mistaken.
Do you tend to rough-turn your blanks, soak, let dry (several months) and then finish turn? Or, rough turn, soak, drip dry (several hours) finish turn and allow to dry further before applying a finish?
Ok, have I confused things yet? This seems to be more appealling process than DNA...at least for me.
Thanks for your help,
Steve Kubien
Re: soap solution
Substitute for Costco? Allen
Bob Fawcett
>We don't have a Costco, has anyone used another brand with success? Any brand in particular, or will any kind of dishsoap work? Is there a majic ingredient we can just look for on the lable? A brand not to use?
So many questions.
Re: soap solution
Questions arise
robo hippy
>As near as I can tell, the soaks do nothing to prevent cracking. The biggest thing here is to control the drying process. If the humidity is too low, if it is too warm/hot, if there is too much of a breeze, if there is a lot of variation in the thickness of the blank, you will get more cracking. Depending on your local climate and shop conditions, you may have to experiment to find out what works best for you. Also very helpful is to turn out all cracks. If any are left in, they tend to open up more rather than be stable. Super glue can help, but won't prevent a crack from opening up more.
Any soap will do, you just don't want the colored soaps (blue and green) as they will color your wood. The brown/amber soaps don't add much color to the woods. After your solution has done a number of bowls, the soap will have its own color. A bunch of black walnut will leave the solution very dark, and this can add dark color to whatever you soak in it.
robo hippy
Re: soap solution
Re: Ivory, Clear, Concentrated,
Allen Neighbors
>Dish Washing Detergent. I buy it at WalMart. Quart bottles. Should be able to get the "same as" in 5 gal size at Sams, etc., big box stores, I've just never tried.
