Stablizing wood
Ray Binnicker
>Ok, I gotta ask. What do they mean when say a piece of wood has been "stabilized" ? I see the term a lot in the pen turning forums. What do you do to "stabilize" wood ?
Ray
Stablizing wood
Ray Binnicker
Ray
Re: Stablizing wood
robo hippy
>There is one process that I know of that involves a polymer liquid (which is about the consistancy of gasoline) which can be colored, and involves a vacuum chamber and a pressure chamber. The vacuum and pressure forces the polymer into the wood fiber and open areas (it doesn't fill holes or cracks) and infuses/satbilizes the wood. You can take punky wood and make it solid enough to turn, and the polymer isn't subject to movement with relative humidity changes.
robo hippy
Re: Stablizing wood
eaglesc
>Essentially it is "plasticized wood" highly over rated.
A sharp tool& patience will accomplish the same thing with the aid of CA.
Some materials like corn cobs, and punky wood or wood that lends to tearing benifit from it but why wait.
That's why God invented CA.
Many of the stabilized blanks are dyed byt the color pretty much is terrible and not very vivid.If you want to turn plastic wood just turn acrylics, the look better.
Re: Stablizing wood
Robert Henderson
>I agree. My experience is that you have to explain to the uninitiated that it "Really is wood, honest!" It has the look and feel of plastic. Why bother?
Re: Stablizing wood
Ray Binnicker
>I was just curious what they were talking about. Thanks for edjumacating me. (:-)
Ray Binnicker
Re: Stablizing wood
John Kyler
>Polymer forced into wood under pressure/vacuum and then heat that makes a wood that otherwise would be unstable to work very nice to work. Making wood easier to turn and that will hold up when used for pens etc.
CA glue has it's health hazards and can cause asthma.
John
Re: I Agree!!!
Carol from AZ
>Those are gorgeous, Jim. They are, hands down, the best looking, most desirable turned pens I have ever seen.
Wish I could afford them! Being a student is very hard on the bank account. :)
Ew! Nasty!
Jennifer@Indy.USA
>Jim,
You're right. Those are horrid. The color is not vivid at all a d the finish...despicable! Why would you choose that over a corn cob saturated with CA glue? I see Eagle's point now.
Toss in the towel on those stabilized blanks. They just aren't cutting it.
Jen :)
Ew! Nasty!
Jennifer@Indy.USA
>Jim,
You're right. Those are horrid. The color is not vivid at all and the finish...despicable! Why would you choose that over a corn cob saturated with CA glue? I see Eagle's point now.
Jen :)
