Routing/Fluting Sled
Bruce Forrest
>I've been asked a couple of times to post some pictures of the apparatus that I used to rout pieces while mounted on the lathe. I guess my explanations left something to be desired. Anyway, for straight flutes it certainly nothing fancy. Just a simple L-shaped sled with a couple of brackets holding the laminate trimmer sliding on a plywood table. The top of the plywood table is bolted to the ways of the lathe (bolt hidden behind sled in the picture) and for added stability, I made a couple of legs out of plywood scraps which just slide in and then out of the way again when I'm finished. Table can be waxed for added ease of operation.
I'll post a second message with a close-up view.
Re: Routing/Fluting Sled
Bruce Forrest
>Here is a closeup view of the sled. Nothing fancy at all. The lathe indexing is used to hold the piece in place and rotate the piece between swipes with the router. That's all it takes for straight cuts. For spirals its more complicated and involves pulleys, drive/indexing wheels and wires to drive the sled, but for straight cuts, just push it at your own pace. Hope this helps.
Steven Antonucci
If you added a small block of wood
Steve Antonucci
>to the front of the assembly, just below the cutting bit, you could automatically control the depth of each cut. (assuming it's not there today or invisible in the picture) It would just follow the profile of the vessel and restrict the router from cutting deeper.
Steve
Re: If you added a small block of wood
>It's also important for the bit to stay perpendicular to the wood. If you are routing a flute that has to curve around the piece it can cut differently if you tilt the router so the blade isn't perpendicular to the cut. This isn't as important on a roundover bit on a straight bit it can really cause problems.
To route curved surfaces I use a pattern on the table that my router sled runs against. Mine has 2 screws that stick out. I can use the screws for really fine depth adjustment and with both screws running against the pattern it will keep the bit perpendicular to the wood.
I won't be home tonight until late so I won'tbe able to post a photo of the jig until late Thursday.
Bruce Forrest
>Actually, the bit extends through a hole in the piece of wood at the front, and the amount of the protrusion dictates the depth of the cut.
Steven Antonucci
yabut...
Steve Antonucci
>Even though the front of the jig is pretty small, I bet it would follow the contour a little bit better if you had a "fingernail" profile set to the same depth. If you were married to the current jig, you'd probably get a more accurate cut from doing a half round profile on the current upright, since the round would follow the profile on a smaller point.
Don' mind me, I'm lying on the couch with a fever today and trying to make lemons from lemonade :-)
Steve
Picture - Drill Jig / Routing/Fluting Sled
Larry In Lima
>Bruce, just wanted to show you another way of doing this, that might work for a lot of people. I just got this jig from Fred in NC.
The silver vertical post is a single machined piece of steel, that is flat on the backside. Because it is flat on the backside, you can get it right up tight to your turned piece of wood. There is a black "set collar" with an allen screw on the base of the post, that allows you to move the jig up and down to center it on your workpiece.
The little black bushing where you see the drill bit running through it is an industry standard thread, which allows you to use 1/8", 3/16", 1/4", 5/16", and 3/8" size bushings. The bushings are fairly cheap and easy to get and replace if you would happen to "booger" one up. If for some reason the head of your drill bit or boring tool is larger than the shank, you can run the shank backwards through the bushing and then chuck it up in your drill or tool.
The post on mine is 5/8" to fit the Jet mini lathe that I have, but they might be available in other sizes as well. I don't know for sure. In this picture, the drill bit is 1/4"
I took this picture without the drill, so that you could see better. I think in this case, a picture really does say a thousand words. If you or anyone else have any questions, feel free to yell.
Fred is not a relative, I have no financial interest in the product, yada yada yada, you know. Larry
Re: Picture - Drill Jig / Routing/Fluting Sled
Fred in NC
>Larry, thanks for posting the pic. I just hate to toot the horn about my own stuff !!! Most of the jigs and accessories I come up with are the result of my own needs, and sometimes others request I make them up for them. Whenever possible, I do !!!
