Dinasore Egg
Dinasore Egg
Dinasore Egg
Mike from Tn.
>5"x6" Black Walnut Stand. The "EGG" is blood Marble that I picked up at the Nashville flea market. I wanted to go a little further on the turn but the core started to fall apart. The walnut tree out of the back yard has done me well. I have another one that will come down this spring. I'm going to try some "green" turning then. Comments?
Re: Dinasore Egg
Re: Dinasore Egg
Mike Cunningham (Cape May NJ)
>Interesting. What exactly is blood marble?
Re: Dinasore Egg
Re: Dinasore Egg
>Well DUH! I had it in mind that you turned the egg from a wood that you were referring to as blood marble and thought that must be a local slang for some sort of wood in your area. It now occurs to me that the egg is in fact marble and the turning you referred to is that which holds the egg. The brain isn't what it was I suppose.
Re: Dinasore Egg
Re: Dinasore Egg
Mike from Tn.
>I haven't the foggest. It's just what the lady at the flea market said it was. So it's got to be true????? I guess it's just a name to denote the color of the marble.
