Vacuum question
Vacuum question
Vacuum question
Mike Cunningham (Cape May NJ)
>I've moved my vac pump away from my lathe. I'm running a line up the wall and over the ceiling to a drop above the headstock. I'd like to use one of those coiled air hoses for the connection, this way it's up out of the way when not in use.. Does anyone know if they crush under vac pressure
Thanks,
Mike
Re: Vacuum question
Re: Vacuum question
Carol from AZ
>No, they don't. But avoid the swivel fittings. They leak.
Re: Vacuum question
Re: Vacuum question
Bob Fawcett
>Remember that all that line will take longer to build up your vacuum. Also more chances for leaks. If you have a high volume pump, it probably doesn't matter.
Re: Vacuum question
Re: Vacuum question
>Thanks Bob. I use a Gast. The line actually only has one additional connection than it did when sitting near the lathe. Rather than run pipe with various joints I'm using heavy duty hose with a quick to connect the flex hose at the drop.
Mike
Re: Vacuum question
Thanks Carol
Re: Vacuum question
That's what I use...
Peter Teubel
>...with standard air hose quick connect fittings. No problems at all.
Re: Vacuum question
Re: That's what I use...
>Thanks Peter.
Re: Vacuum question
Re: Vacuum question
Bill Turpin in WNC mountains
>Vacuum efficiency is inversely proportional to the square of the distance or orifice. Hillbilly translation: Twice the distance = one quarter the vacuum. Half the orifice = one quarter the vacuum. It does not take much of either to SUCK away your vacuum! Refrigeration mechanics use long hoses and 1/4 inch access ports to suck vacuums on systems before charging. They buy very expensive and HEAVY pumps for faster evacuation. They are kidding themselves... the small orifice determines everything, not the extra hundreds of $ they wasted on a larger pump.
Bill in WNC mountains
NC Refrigeration Lic# 2821
Re: Vacuum question
Bob Moffett
Re: Vacuum question
Bob Moffett
>I also use the coiled hose with a quick connect female connector on one end and a male connector on the other end. I've been using that for about 3 years with no problem. I also have a piece of 4" PVC pipe under a shelf that I use to store the hose and if fits perfectly.
Re: Vacuum question
Re: Vacuum question
>I'm pulling 22 at 18'
Re: Vacuum question
Re: I'm curious about the connectors?
Jamie Donaldson
>Don't the quick connect fittings rely on positive pressure to make the seals operate and airtight? It seems to me that this seal would not work in reverse, as a vacuum would effectively be pulling the seals in opposite directions. What's the story?
Re: Vacuum question
>Hi Jamie,
I'm using quicks and have always used them, regardless of where the pump was located. I've no idea regarding the mechanics but they work just fine.
Mike
Re: Vacuum question
Carol from AZ
>There was one quick disconnect that didn't work well for any of my students. That was the one-handed 'automatic' one. We used cheapies from HF and nearly all of them worked just fine, or they were quickly replaced! The swivels leaked so badly, we could feel it.
This was a syllabus I developed for a community college called Vacuum Technology for Woodworkers. In the class, everyone built a vacuum system and a number of vacuum clamps. The final test was set up your rig, pull a vacuum against a non-porous surface (we used acrylic), and shut everything off. Now the contest was on. Whose system held vacuum the longest? Every system had a gauge and readings were made irregularly over the next week. Great fun and everyone came out of it with a working systems, a half dozen jigs, and plans for tons more. Every jig you designed and made, you offered plans for everyone else in the class. Cameras were always welcome.
