Hollowing tool advice
Barry Scotton.... on SaltSpring
>I have been using the Don Pencil scorpion, for deep hollowing, vases etc. and have been quite satisfied with the tool. It occurs to me that I may get a smoother cut on end grain and side grain using a ring or hook tool. The oneway termite looks interesting, but you need a router to sharpen the cutter. I dont own a router. The Martel hook tool looks interesting, and is some what cheaper. I would appreciate comments and advice on what you use, are there other alternatives, is there a ring or hook cutter that what fit on my scorpion? Thanks in advance for your help.
Re: Hollowing tool advice
>Barry Anything that rotates will work to sharpen the oneway tool. I use a drill press but I think with a little rigging you could probably use a drill, flex shaft machine or even a dremel. On the Dremel you would have to use thier stone instead of oneways. I sharpen my Forestner bits using the Dremel.
Tommy Holmes
>Can you explain how you sharpen your forstner bits with a dremel?
electric drill works fine
robert davis
>I take a white tapered cone shaped grinding stone in the Dremel and run it around the inside curve. I always start too shallow so it's polishing the bevel above the edge and then gradually tilt the toll until I'm polishing the whole bevel.
Then I very carefully grind the top of the flat cutting surface. After I've used the dremel I take a flat diamond hone and run around the outside of the curved part very lightly to remove the burr. Then I run it up the slanted portion of the flat cutting surface to remove the burr and also to flatten this surface.
I have a set of the real cheap tiawanese drill bits and have been able to sharpen them successfully many times.
On the Saw tooth edge ones I use the diamond hones by hand to hit the cutting edge of the teeth after I hone the round inside portion with the Dremel.
Gary Ljostad
>Barry, I have both the Oneway termite and the Martel hook tools. While both do the job, I really like the Martel Hook. I have much more control and can make a few different cuts with it. I watched Andre Martel demo it and was sold. Now it is my go to tool for end grain hollowing.
Gary
Tommy Holmes
>Thanks John. I am at the point a couple of mine need sharpening and had begun wondering how to sharpen them without taking them to a professional.
That's what I use.
Eddie Pacheco, San Jose, Ca.
>No way was I going to mount the supplied sharpening stone in a router.
>Thanks John and Garry. Garry does the Martel tool have any use for you as far as side grain hollowing goes, and does it give the smooth cut I am anticipating?
Approximately how much does the ...
Ed Moore
>Martel tool cost?
I too am seeking a good end grain tool with a gentle learning curve. I noted the caveat that one should rotate the tool so that the elbow is up. I assume that the tool is used with the hook riding the bevel at about 10:30 or 45 degrees from straight up.
Please enlighten me.
Ed
Correction!!! NOT! NOT!
Ed Moore
>"I noted the caveat that one should NOT rotate the tool so that the elbow is up."
Mea culpa,
Ed
Mike from Tn.
>Actually I've got two sets of the not just cheap but really cheap forstner bits. For the price of the two sets I could have bought a decent set but live and learn. I'm going to give your method a shot John. If I can't do it your really not that far away. Just kidding.
Brodie Brickey
>Barry,
I don't really do any deep hollowing. Total depth is 6.5" at most for my end grain turnings. I use a Oneway Termite� and a similar ring tool made by Jet (a lot cheaper, but much larger hole like �") I picked it up at the Pasadena Symposioum for $37.00.
They both work fine. I've found that I can really hog out the opening, but they may take more out of one side than the other unless you go slow. The Oneway Termite� has a tendancy to clog a lot due to the narrowness of the ring. The Jet tool less so because its larger.
Regards,
Brodie
http://www.SmoothTurning.com
georgetroy
>You will need to get a shaft that will fit separate hook end, straight bit or Oneway termite hook. Take your sharpening suggestions from there. GT
>Mike Your welcome up anytime. I looked at the good sets of Forestner but they were about 4 to 6 times as expensive.
Malcolm Tibbetts
>Barry, you might consider the "Eliminator". It's a fairly new tool and only available through Packard. I recently started using the 3/8" model and I've been very impressed. It "cuts" and leaves a very smooth surface. The cutter is similar to a ring tool, but without the hole which can plug up. The cutter is carbide and repositionable, so it should last a long, long time (no sharpening). And a replacement tip is only about $15. Perhaps the neatest thing is the shaft has a flat side so you always know how the tip is positioned.
Jimiles-Charlotte, NC
>I use the Termite a lot. ( been wanting to try hook also )
I found the sharping bit supplied with it to be pretty worthless.
Get a cone shape dremel bit at Lowe's ( $2 - 3$ ) use in dremel or drill. For a shaft suggest a 1/2 to 5/8 inch diameter metal rod ( Lowe's also ) drill end to fit termite and tap for set screw to hold.
The length and heft will really help for deep hollowing. Use round foam pipe insulation around your metal shaft for cushion
>Thanks to all who responded, your help is appreciated
Re: Hollowing tool advice *LINK*
Darrell Feltmate
>Barry
The termite is a great tool, but for fun you can make your own hook tools. I use a home made one for all my end grain turning and sharpen with a Dremel. Take a look at http://aroundthewoods.com/hooktool.shtml for how to make one and http://aroundthewoods.com/hookuse.shtml for how to use one. The latter is great whether you make or buy a tool.
Around the Woods
