Burning rings in the flat rim of a bowl.
Al Crandall (N.E. of Indy)
>Has anyone tried using the edge of a penny held in vicegrips to burn a ring in a flat surface? It might give a nice crisp edge to the ring. The process would be similar to using a wire to burn rings around the circumference of the bowl.
Re: Burning rings in the flat rim of a bowl.
Jimiles-Charlotte, NC
>Have not tried penny. I use a scrap piece of Formica. It works great. You can even put a line inside a bowl where a wire would never work.
>I've also used formica and hardboard. I'll have to try the penny. You should have titled this "a penny for your thoughts" but then you probably wouldn't lower yourself to something that silly like I would. If a penny works would a gold coin work better?
Ric Taylor
Ric Taylor
>Somehow in my mind, I can't seem to force vicegrips and a gold coin into the same picture. .... :)
Mike Rubes, Apex, NC
>Hi all,
I've used the formica chips and they seem to work pretty well. Not nearly as well as a guitar string on the outside of a bowl, but still pretty good. Like others, I've done the formica method to burn lines inside a bowl and the effect can be really neat.
I'll have to give the penny a try, I like that idea.
Thanks!
Mike
Sweet aroma of slightly burned cherry lingering in the shop in Apex, NC
Roger Smith
>Al, another thing you can use is a wedge of some type of oily hardwood. I have use a piece of purple heart several times. It actually transfers some of the color during the burning process.
roger
Terence Rice
>Metal is an excellent conducter ofheat. Formica and wood are much less so. Since you want the heat to build up right where the tool and the turning meet you are better off using something that conducts heat slowly. Gold is an even better conductor than copper so it is going to work less well.
I hadn't thought of using formica. Thanks for the tip.
Re: I'll try the formica too. Thanks guys.
Bill Hale / Woodspinner
>Oh they do ! I use a kougerand. ?? sp
Bill
Re: Wasn't impressed with the Formica.
>I had some rings to burn on the outside of a deep vase, and decided to use Formica instead of wire. Should have used wire. The Formica melted and mushroomed and left an irregular edge on the burned groove. Results might be different on a flat surface which is where I originally asked about and is where everyone suggested I try this product.
Small Screwdriver....
Wally Dickerman in Arizona
>Al, I use a very small screwdriver for burned rings. Works very well. I grind a new sharp edge on it for every use. I usually cut a small groove with a spearpoint, crank up the speed and push the screwdriver into the groove. Friction heat does the burning.
Wally
