A55 Smoothing Plane
Table saw sleds
Table saw sleds
Keith Tompkins
Table saw sleds
keith tompkins
>I just wanted to make a few comments on table saw sleds, especially after reading about Bill Hale's accident. Bill, I hope the thumb recovers quickly, but it would certainly be much better if the accident could have been prevented. This may help someone in the future. There are two main reasons for using a sled instead of miter guages or other methods. First, the sled is very stable, and in most cases,a sled is much safer than other methods.
All pieces cut on a sled should be secured to the sled...either with commercially availabe clamping devices or home-built clamps. That way, even small pieces can be run through the blade without being held in place with your hands. With the piece being cut clamped in place, you push the entire sled through the cut, with your hands nowhere near the cutting path of the saw. Running pieces through the saw with unclamped pieces in the sled is not a good practice, and forfeits the safety aspect of a sled. Hope this helps.
Re: Table saw sleds
Re: Table saw sleds
>I have a "red zone" around the blade on my table saw. My hands never go into this red zone for any reason. Sometimes I have to build a special push block to hole a piece properly but I value my fingers too much. I almost never push a piece of wood through the saw by hand. Once you use a push block enough it's like using your hands and you get very accurate cuts without gettting your hands near the blade.
One thing I don't see on many miter sleds is a place for the blade to go after you cut. I add a hollow block to the back side so the blade never gets exposed and there isn't any possibility of cutting a thumb or finger as you push the sled through.
I use either homemade clamps or quite often a pencil with eraser to hold small pieces when I cut them off.
Most injuries in our field occur with the table saw, bandsaw and chainsaw followed closely by things flying off the lathe. Keep these in mind everytime you get near one of those machines. My only serious injury has been with a carving knife and it happened just like all injuries. I was doing something that I knew I shouldn't do but did it anyway. Payed the price.
Re: Table saw sleds
Never push a small piece ...
Ed Moore
>away from the BACK of a table saw with a finger or pushstick. DAMHIKT
If the back of the blade catches the pushstick it will lift it and throw it forward. I did this and the stick was flung forward and it struck my left hand, which was on the back of my Dubby sled. The knuckle was buggared up pretty good.
Incidentally, I just sent Keith's remarks to my older son, who loves woodworking. He responded that he has been looking at an Incra Miter sled. I think we have convinced him to get one.
Ed
Re: Table saw sleds
Re: Never push a small piece ...
georgetroy
>In my opinion unless you have a mechanical hold down on your sled you at risk. That's why I like my Smart Miter system. I don't think the Inca has it. Besides I have arthritis in my hands and they are not as strong as they use too be, like the rest of me. I saw a photo that someone had posted with a home made sled that has a hold down. GT
Re: Table saw sleds
Re: Table saw sleds
Bob Fawcett
>The sled I just built has 2 hold downs. I put one on either side of the blade. I did this to keep temptation from pulling one of my fingers to hold the unclamped part of the board.
Re: Table saw sleds
Re: Table saw sleds
Doug Turner
>I also included a lexan strip about 3/8 thick and 4 inches wide as a blade guard. This reminds me of the spinning blade and hopefully will deflect an accidental kick back from a small piece catching in the blade.
Re: Table saw sleds
Re: Table saw sleds
David Walser
>In Malcolm Tibbett's book, he shows how to make a table saw sled for cutting small pieces for segmented work. His design adds an extra "level" to the sled's construction. The sled has a "base" with runners. Attached to the base is the "fence" that controls the angle of the miter cut. In front of the fence, and on top of the base, is strip of wood that holds the piece of wood to be cut. On the left side of the blade, the strip of wood is 3 - 4 inches wide and 3/4" thick by the length of the fence. On the right side of the blade, the strip of wood is wedge shaped. It is 3 - 4 inches wide and tapers from 3/4" thick next to the blade to nothing in a length of about 3". The idea is that once you've cut your small piece, it will fall onto the wedge on the right side of the blade and slide away from the blade. No need and no temptation to reach close to the blade to grab your cut off.
Hope the explanation is clear. Malcolm does it better -- and his pictures help.
Re: Table saw sleds
Re: Table saw sleds
Russ Fairfield
>It seems to me that any time the cut-off piece is captured between the sawblade and a fence, there will always be the possibility of it being picked up by the saw, UNLESS it is held down so it can't go anywhere.
Since clamping is all but impossible, and difficult at best, for cutting small pieces, it seems to me that the next best thing is that the fence not be there to capture the cut-off. That means a moveable fence that can be used for positioning and then moved out of the way for cutting.
It also seems to me that the safest way for cutting small pieces of wood is rough cutting them to a layout line on a bandsaw with a fine toothed blade, and then sanding them to the final dimension on a disc sander. Some usefukl sanding jigs are shown in the Ray Allen book that was authored by Dale Nish.
Anyway, that's my opinion. Feel free to disagree.
Re: Table saw sleds
Re: Table saw sleds
MountainMan
>Hey! did you guys catch "ask this ole house hour" last saturday?? Tommy demo'ed one of the wenie table saw blade stoppers... Very Impressive!! He put a frank on the sled - held onto it with his hand like he was going to do a crosscut on a peice of wood - the nanosecond that the blade touched the meat--- the blade insantaniously stopped spinning and went down into the inside of the saw cabinet!! There was not even a nick on the meat!! I hear the price tag is pretty high - not only do you destroy your blade - the stop itself is destroyed too!! But!! You still have all ten digits!!
Regards
TheMountainMan
Re: Table saw sleds
Table saw? What's a table saw?
Rick Davenport
Re: Table saw sleds
Re: Table saw sleds
Neal in San Jose
>Yep, that's the contractor's version of the SawStop. I bought the cabinet saw version and don't regret it for a minute. Lots of controversy over the price, but I place a high value on my digits, so if it is worth it to me. A replacement cartridge will be $60, and a new blade will be another $60 to $100, but a trip to the emergency room will be much more than that. I look at it like the air bags in my car: I hope I never use 'em, but if I do, I'll be glad I had them. The first time I saw the live demo, I was sold.
Neal, who got 4 stiches because of a band saw accident 50 years ago, and has been VERY concerned about keeping body parts attached ever since.
P.S. go to their website; Sawstop.com and click on the demo.
Re: Table saw sleds
Re: Table saw sleds
Jimiles-Charlotte, NC
>I agree with having a big block of wood at the back end of the sled so that when you have pushed the sled through the blade is still covwered up. What you also need is a stop to stop the forward movement of the sled so it dosen't cut through your block.
Would'nt cross cut anything on table saw without my sled, also rip a lot of short pieces on the sled
Re: Table saw sleds
Re: Table saw sleds *LINK*
eaglesc
>Re: Table saw sleds
Russ Fairfield -- Monday, 26 February 2007, at 1:45 p.m.
<"It seems to me that any time the cut-off piece is captured between the sawblade and a fence, there will always be the possibility of it being picked up by the saw, UNLESS it is held down so it can't go anywhere.
Since clamping is all but impossible, and difficult at best, for cutting small pieces, it seems to me that the next best thing is that the fence not be there to capture the cut-off. That means a moveable fence that can be used for positioning and then moved out of the way for cutting." >
Russ I agree with you whole heartedly, but clamping small pieces is not impossible as you say. I do it everyday on my contractors tablesaw with my sled.
I made this vacuum fence and use scrap stock to hold the pieces down.Fingers are out of the way on both ripping and crosscutting operations.
No need for a Gripppper or a hot dog nicker saw.
It takes common sense not gadgets.
I typically rip stock at .020 thickness and cross cut pieces smaller than 3/4" sq.
Blade set just to clear the stock and waste block on top as a hold down.
I woul;d dream of making the cuts I do on a CMS.
vacuum fence
Re: Table saw sleds
Fixed *LINK*
Ron in Drums PA
Vacuum Sled
Re: Table saw sleds
You might have converted it to a work bench
Ron in Drums PA
Re: Table saw sleds
Re: Fixed
eaglesc
>Thanks Ron
Re: Table saw sleds
Re: Table saw sleds
Malcolm Tibbetts
>David, I think I�ve posted this photo before, but for anyone interested, here it is again. As you stated, the �safety� feature is the little red ramp which keeps the cutoff from having any further contact with the blade. Another safety feature to this design would be to include some sort of enclosure for the blade on the back side of the fence. On this sled, I have not shown a hold-down clamp, but that can be easily added. The fence is not repositionable; it�s locked at 11.25 degrees. The fence also has a strip of 80-grit sandpaper attached which prevents board slippage. The �stop� is attached to the saw fence and is easily repositioned.
