Daylight balanced lighting ... big difference *LINK*
Jeff from MA
>I just did a little upgrade to the 46" fluorescent T12 tubes that I use in my windowless basement shop. The old tubes were 2300 lumen, 32 watt, 4200Kelvin.
I just replaced 8 of them with 5000 Kelvin, 3600 lumen, 40W bulbs. What a difference!!! Not only can you see detail and color better, but it is much easier on the eyes. The lights I put near my photo area are good enough so the camera is now able to use its full range of F-stops, it could only do about half of the range previously. I would recommend that anyone who doesn't have natural light give these or similar bulbs a try.
http://www.fullspectrumsolutions.com/product_105_detailed.htm
Re: Daylight balanced lighting ... big difference *LINK*
Re: For many years I have used......
Jamie Donaldson
>.. F40/CWX (Cool White Deluxe) as daylight equivalent tubes in all the fixtures in my photo business. They are usually available at the big box lighting stores and are reasonably priced. However, don't use fluorescents as primary lathe illumination because of the documented occurrances of strobe induced seizures in some susceptible individuals.
>I replaced all the lights in my shop with 5000K flourescents because my wife was convinced I needed more daylight. Something she say on Opra or one of those other BS shows. Other than the color being different and the lights costing a lot more I couldn't tell a bit of difference. It does allow you to shoot photos using the daylight setting on your camera but that was about the only benefit I got out of them.
Re: Question for you:
Allen Neighbors
>Jeff, that sounds good to me. I need to do something in my shop to increase the quality of light.
I have a question for you. Will the added wattage of these tubes put a strain on the ballast in a 4 foot shop light? (I always thought my tubes were 20 watt.)
Thanks in advance.
Jeff from MA
>I think you would have to check the specific light fixture that you have. There should be a sticker or plate on the fixture indicating maximum wattage If it's not on the fixture it should be on the ballast.
Jeff from MA
>I used to be able to see the flashing, it was especially bad when using a computer monitor or a display of some kind. But over the last few years I am guessing that the bulbs have gotten better, and I know my eyes have gotten worse. ... just got reading glassing last week. :(
>Jeff Sorry didn't mean to sound so negative. They do add a very nice color to your workspace. I've never had a problem with strobing affect although I do notice it when the lathe is slowing down. I was demonstrating once at night on an outdoor show and a lady stood back and asked me if I could turn the lathe off. She explained that it would cause her siezures if she saw it under the flourescent lights.
Dinyar Chavda
>Jamie said, "However, don't use fluorescents as primary lathe illumination because of the documented occurrances of strobe induced seizures in some susceptible individuals."
You meglected to mention the other, far more serious, effect of strobe lighting causing an uncontrollable need to dance disco!
>Dinyar I was in the Air Force during the 70's and missed the whole disco thing, which is quite fortunate for all my friends because I can't dance. Well maybe a good slow dance but not that moving your hips thing.
Ric Taylor
Ric Taylor
>John,
I was also in the Air Force during the 70s (.....and 80s .....and 90s ...), and during the 70s there was a whole lotta disco going on in my squadrons!
Ric
