Replacement blade shank size
Doug Thompson near Cleveland
>I need your thoughts and ideas;
Tool steel is sold .015 (1/64) oversize and as is will fit all aftermarket handles except a 3/8 in a Oneway because it's the same size, this shank size needs to be turned down a bit.
To make your own wood handle would require a drill bit 1/64 larger than a commom size. Example; 1/2 - 33/64, 5/8 - 41/64
Should a 1/2 - 5/8 tool shank be turned down or not?
What are your thoughts or am I worried about fifteen thousands for nothing.
Re: Replacement blade shank size
Bob Fawcett
>Most people have drills up to 1/2" in regular twist drills. most don't have a 33/64" bit in anything. Is the extra machining operation worth the cost of a drill bit?
Ronnie
>If you are making a wooden handle ,drill it as close as you can , run the bit in a couple of times , put the ferrule on and drive it in for a tight fit.I've make several with no problems.
Ronnie
Offer both sizes
Ray Thompson - Middletown,IN
>Make your standard tool the one with the oversize steel and offer a turned down shank for the extra cost of machining. Satisfies everyone, except the guy who has to handle all the different products. But then he is a bright guy and can handle anything. ;-)
Ray
Re: Most wood bits have enough...
Jamie Donaldson
>... wobble to compensate for those tolerances.I certainly wouldn't want to spend extra money to have a larger shaft machined to a smaller size.
Jamie, the tools you have are not ground problems?
>this is the standard stock size. What handle did you use or did you make your own?
I don't think
>.016 slop in a drilled hole would be a common occurance. Having that much would indicate a problem somewhere. A few thousandths over I could see but not that much.
Ray
>Doug Most woodturners don't want to mess with trying to buy odd size drills or drilling too big a hole and then filling with epoxy. Personally I would just drill it half inch and then heat the end and drive it in the handle but I would dare say no more than one or two in the two clubs I go to would try that.
I think I would turn them down to common sizes unless the cost gets prohibitive. For one thing If I were to make an aftermarket handle to sell I would probably make it a common size such as 1/2, 5/8, or 3/4.
What's the old trick Ray...
>Sharpen the bit so the point is off center... that's good for a few. LoL
Re: Doug- they mounted right into ...
Jamie Donaldson
>... 2 old Sorby handles without any redrilling. I prefer wooden handles over metal, and I can see that the metal handles would create more of a fit problem.
>Thank you Jamie... interesting.
You decided and here's what will happen
>The shank WILL be turned down to a commom fractional size. This is a extra step that I couldn't decide what to do. I will keep a few aside to fit a old Glaser handle.
THANK YOU!!!
Yep, grind one flute longer than the other
>and you can drill oversize, not a lot but oversize. A properly sharpened drill will drill to size, it may not be straight, but that's a subject for another thread. Dad always said he could grind a drill to drill undersized, but I never figured out if he could or just pulling my chain.
Ray
Re: What's the old trick Ray...
>sharpening off center will work but if everything is not clamped in place it will drill an oval hole.
Re: You decided and here's what will happen
Jerry from Lapel In.
>I want mine turned down with a deeper flute.
Yeah, it will be oval, big, ragged
>and just plain ugly, and if you get to carried away the drill may break.
Ray
>and just plain ugly, and if you get to carried away the drill may break. If you need an oversize hole there are far better solutions.
Ray
>Jerry,
You got .020 of that back. While I think of it the Ohio valley woodturners are having a symposium in October don't plan the Indyfest the same weekend. I would like to attend both.
Who said turn the shanks down... I just finished!
