Finishing Cedar
Finishing Cedar
Bob Moffett
Finishing Cedar
Bob Moffett
>I am turning a series of Cedar natural edge bowls. What is a good finish to use on them? I tried Deft on one and it looked good for a while and then spots started to appear in the finish where there appeard to be no finish anymore. I am trying some Waterlox now (3 coats sealer & 3 coats gloss) but it doesn't appear uniform. I have been using the same formula of Waterlox on my other bowls and it looks good, but not on cedar. Any suggestions would be appreciated.
Re: Finishing Cedar
Re: Finishing Cedar
Allen Neighbors
>Bob, most of the time, I use a wash of 75%Thinner/25%Lacquer... wet coat it, and the immediately wipe it off. Then I let it cure overnight, and buff ite with Tripoli, White Diamond, and Carnauba. It really makes the colors pop. Some say that it causes the sap wood to yellow some, but I've got some that I've done this way that haven't yellowed any that I can tell. At any rate, they still look fine.
Re: Finishing Cedar
Re: Finishing Cedar
Ralph Watts
>Bob,
Cedar contains an oil that inhibits many types of finishes from completely curing. A simple solution is to coat the piece with shelac then use most any finish you want.
Re: Finishing Cedar
Re: Finishing Cedar
Wolf Kiessling
>A few years ago I carved a couple of stylized pieces out of aromatic cedar which had some really pretty color. I finished these pieces with Danish oil. Both pieces destroyed the finish so I sanded them down and refinished again with the same result. I contacted the Flecto Co. about this and they recommended using nothing but wax. They said the volatiles in the cedar MIGHT eat any finish that would be applied and in some cases it might even take a few years.
I have heeded their advice and used nothing but wax over cedar and have not had any more problems...... FWIW
Re: Finishing Cedar
Re: Finishing Cedar
Rick Davenport
>I've turned a half dozen cedar bowls, three with a natural edge.
I sanded them to 800 grit and left them "nekkid."
They smell good, they feel nice and people use them to hold assorted junk in their walk in closets.
Every time I display one, I sell it.
R
Re: Finishing Cedar
Bob Moffett
Re: Finishing Cedar
Bob Moffett
>Thanks for the information. I give these suggestions a try.
Re: Finishing Cedar
Re: Finishing Cedar
Russ Fairfield
>It doesn't matter whether it is Eastern, Western, or any number of ornamentals in the same family, Cedar is a tough wood to finish.
Cedar is a very porous wood that will drink up great volumes of whatever liquid we put on it, and there will always be some areas of the piece that will drink more than others. Trying to overcome that difference is usually a losing battle bedcause there will always be more finish in the more absorbant areas than on those that are less absorbant.
The other problem is that Cedar has a lot of natural oils, some more than others, and sometimes more in one area than another on the same piece. These natural oils will conbine with the finishing oils, solvents, or the finish itself and make it softer and with less gloss. The more oils, the worse this problem. It looks even worse when there is an uneven distribution of oils in various parts of the same piece of wood.
I have found only 2 finishing methods that work for Cedar of any kind.
One has already been suggested. Sand, DO NOT BuFF, to a high gloss, and then do nothing - no finish, no wax, not anything. Buffing doesn't always work because some amount of the Tallow and wax carriers of the Tripoli and White Diamond will be absorbed into the wood, usually into any end-grain, and guess what? The oils in the Cedar react with the residual tallow and wax and make shiny and dull spotts.
The other finishing method is to sand the Cedar to the same surface as the "Do Nothing Method", and then submurge the piece of Cedar in an oil finish long enough for all of the oils to be mixed together, and the wood to become filled before any of them have a chance to cure. Adding some varnish to the oil finish helps add some body and hardness to the wood. Two hours to several days is a good time. Then remove it from the oil and give it a week to dry. Then sand and buff as desired.
The downside of immersion is that, Yes, the color of the wood will change and it will be darker than you may have wanted, and every place where you bruised the wood during turning and sanding will be obvious; but the appearance and gloss on the surface will be the same all over. I like this method because there is always the possibility that I might reveal a hidden grain pattern that would not be there with any other finish.
