How to grind cutters
Phillip
>How do you grind the cutters used in Oland type hollowing tools?
Re: How to grind cutters
Allen Neighbors
>Phillip, I grind my cutters so the cutting edge has about a 42 degree angle.
I ground a 3/8" deep place in my grinder toolrest that is just barely wider than my grindstone. That way, the toolrest fits "around" my grindstone... so to speak.
I tilt the toolrest to an angle, so that when I hold the bit flat on the rest, the stone will grind about a 42 degree angle on the end.
I curve the end of the cutter, so it looks about like my little fingernail.
On some bits, I grind the left edge about 1/2" up the shank. On some bits, I grind the right edge about 1/2" up the shank. These toolbits are very versatile. You can use them to shear cut.
Re: How to grind cutters *LINK*
Eddie Pacheco, San Jose, Ca.
>Don Pencil, the maker of the "Scorpion Hollowing Tools", has a nice tutorial for sharpening the cutter inserts for his system. Some of the process steps can cross over to your hollowing system.
Scorpion Hollowing System
Re: I learned the quickie way.....
Jamie Donaldson
>..from David Ellsworth, and it is too simple! Round the edges of a 60 grit wheel and grind the bit in the tool by grinding it up each side of the bit as desired. Adjust the angle of the grinder tool rest to the desired angle and it supports the tool at the desired cutting angle. John Jordan has a slick jig for sharpening these bits, but the Ellsworth way negates removing the bit from the tool holder.
